997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Oct 31, 2018 12:52 pm    Post subject: Reply with quote
Look what the postman brought me, a nice new 996 roof panel.
I have a few jobs I want to get finished before I take the old roof off, but I didn't want to get stuck in until I knew I had the panel, it has been on back order for months.
MisterCorn
PostPosted: Wed Oct 31, 2018 1:17 pm    Post subject: Reply with quote
With the centre radiator bracket fitted in front of the GT2 ducting there was about a 20mm gap all the way along the underside.
With this large gap there could be a tendency for air to come out of the radiator and go underneath the car rather than on top, although the air pressure on top should be lower anyway which would help it go the right way.
Just as an extra bit of help I bent up a piece of aluminium to fill the majority of the gap up. The fabricated brackets for the bottom have now been painted and screwed in place as well, so this is now ready for the radiator to be bolted in.
demon
PostPosted: Wed Oct 31, 2018 3:26 pm    Post subject: Reply with quote
Embarassed - I may be to blame for that - I snatched up the last one listed on stock back in June....
Kind of amazing the sheer lack of any internal structure to the non-sunroof roof - the fact that its basically just a single mildly shaped skin/panel with folded edges... for some reason I expected there to be more to it
1998 Carrera - Black, no sunroof, manual, cable throttle, IPD plenum, 200 cell x pipe, cargraphic backboxes, Ohlins R&T, LSD, polybushed, Girodisc brakes, custom ("shaved") GT3 RS decklid, 997 sports seats, litronic headlights, RUF wing mirrors, Hartech rebuild, >240,000 miles
MisterCorn
PostPosted: Wed Oct 31, 2018 3:29 pm    Post subject: Reply with quote
demon wrote:
No worries, I have kept myself busy anyway Smile Have you got any tips on roof removal / refitting?
demon
PostPosted: Wed Oct 31, 2018 3:48 pm    Post subject: Reply with quote
I printed pages 4-5 of Richard's (ELA) thread as my starter... : )
CLR Project Leichtbau: adding lightness to the tune of 250kg
Basically just a lot of spot welds to remove and replace, but otherwise straight forward
My only dramas were re. the rear screen external trim seal
i.e. there is a pair of parts listed for each of the screen/frame/trim - a pre '99 and a post '99 (or there abouts) - each part fairly clearly shows the year application except for the seal... with the confusion then seemingly shared across all parts suppliers(!)
Essentially the rear screen should survive removal and replacement, but frame and seal are always both recommended to be replaced
The first seal sent out was "inches" off! i.e. the bottom has a formed 90 degree corner on each side, then a "loop" between them - the first seal was way too wide to ever fit correctly across the bottom
After a lot of back and forth Porsche (via D911) agreed to send out the "identical/discontinued" alternative part..... that one was a closer fit, but still didn't fit with german precision!
- in the end the new seal still had to be cut and glued - chose to do so on the passenger side right angled corner where it is as invisible as possible
....long story short - be sure to bring all the new parts together well before you fit them - in any case, retain the "old" seal, even if it has to be cut away to remove the screen so that you have a clear comparison.....
classic unexpected PITA!
MisterCorn
PostPosted: Mon Nov 05, 2018 10:37 pm    Post subject: Reply with quote
Started putting the subframes back on the car. No massive rush as I'm still waiting for suspension parts, but st least I can get the rear done.
MisterCorn
PostPosted: Mon Nov 05, 2018 10:51 pm    Post subject: Reply with quote
I have finished the wiring loom for the third radiator controller. I wanted this to automatically turn the radiator on above a certain temperature, give an indication to the driver for this, and also allow a manual override. For the switch I used a heated seat switch as it has two different colour leds in it, plus backlight. I had to modify this as it runs a common gnd and switches to that with 12v needed to drive the leds. I needed the opposite so the leds were unsoldered and turned around. The feed for the second led comes in on a swtich contact but I needed it on the other contact so a track was cut and wire link added. Finally I had to stop it operating in the off direction as I am using a timer to turn it off, some simple pieces of card do the job here.
In operation the swotch shows yellow and red when operated by the thermostat and yellow only when on the timer. The time is adjustable but I will probably set to 5 minutes. This is only really needed for when bleeding the system.
Complete system consists of two relays which will mount in the fuse box, the switch which will go in the horseshoe, the thermostat in the return line just before the engine thermostat, and the valve which goes inline at the inlet to the centre radiator.
The thermostat will be set such that when open the temperature is still above the thermostat opening temperature, so with a 78 degree thermostat something like 95 degrees.
coullstar
PostPosted: Mon Nov 05, 2018 11:22 pm    Post subject: Reply with quote
Very neat.
maldren
PostPosted: Tue Nov 06, 2018 8:39 am    Post subject: Reply with quote
MisterCorn wrote:
The thermostat will be set such that when open the temperature is still above the thermostat opening temperature, so with a 78 degree thermostat something like 95 degrees.MC
Have you thought about setting the new radiator to come on with the low speed fan?
Mike
MisterCorn
PostPosted: Tue Nov 06, 2018 8:49 am    Post subject: Reply with quote
Yes, but I will have aircon on the car and the low speed fans run whenever this is turned on. By the time the high speed fans come on it is getting pretty toasty. Besides, that would be way too simple.
maldren
PostPosted: Tue Nov 06, 2018 8:58 am    Post subject: Reply with quote
Good points, that's about the temp you want though.
Mike
demon
PostPosted: Tue Nov 06, 2018 9:42 am    Post subject: Reply with quote
Now what would be really interesting... would be some kind of oil temperature sensor that indicated when the oil had reached a certain temp - kind of like a light indicator in a factory switch housing that went out when the target temp was reached (at whatever temp at whatever possible pickup point made sense)...… if it could go from red to yellow then off, that would be perfect...… just saying Laughing
Having an early car with a GT3 console delete I have 2 factory blanks in the centre tunnel behind the ashtray - my dream is to eventually fit and wire a garage door opener to one (after I fit a power roller garage door!)... and have a "low oil temp indicator" in the other - that may actually be my nirvana (tragically!)
MisterCorn
PostPosted: Tue Nov 06, 2018 9:47 am    Post subject: Reply with quote
I'll look in to it, I did think of having a switch to switch the temperature gauge between water and oil, but your idea would also work well.
MisterCorn
PostPosted: Wed Nov 14, 2018 12:04 pm    Post subject: Reply with quote
I finished testing the solenoid using a hot air gun to trigger the thermostat, it all works nicely. Unfortunately when I came to fit the bracket after painting the radiator brackets I found there was interference with the air-con pipes, and the outlet from the solenoid didn't line up very well with the inlet to the radiator. So time for a new bracket. This moves the solenoid further back and down, and rotates it slightly. As you can see it now fits and lines up.
I was hoping to keep the water inlets at the top of the radiators so that they are easier to bleed, but that caused even bigger clearance so they will go at the bottom. This is how they are on the GT2 so I doubt it will be an issue. The radiators will be vacuum filled and there is a bleed on the top in case I want to manually bleed them. The drivers side needs a little bit of extra pipework to make that fit, that will be shown when the parts arrive.
One of the handbrake cables needed to be changed so I thought I would do both. After about an hour and a half I managed to get both sides off, it was far from easy. The tubes on the car will be cleaned up and protected before the new ones go on.
kas750
Reims
2006 Porsche 911
PostPosted: Wed Nov 14, 2018 12:06 pm    Post subject: Reply with quote
Loving this thumbsup
NedHan79
PostPosted: Wed Nov 14, 2018 3:59 pm    Post subject: Reply with quote
Looks great. I'm new on here so just getting a chance to read some of the threads. Some very helpful info on there.
MisterCorn
PostPosted: Fri Nov 16, 2018 12:08 pm    Post subject: Reply with quote
The return side of the front radiator is plumbed in. I needed to use a 90 degree bend and an elbow to get from the new lower outlet on the radiator back up to where it should be, whilst avoiding the horns.
Marky911
PostPosted: Fri Nov 16, 2018 6:10 pm    Post subject: Reply with quote
I'm loving the rad controller. Clever stuff. Thumb
MisterCorn
PostPosted: Fri Nov 16, 2018 8:46 pm    Post subject: Reply with quote
Torqued up the RSS studs before fitting the rear hubs so I can get in with the torque wrench. New handbrake guide tubes fitted.
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Sat Nov 17, 2018 12:36 am    Post subject: Reply with quote
Great work.
Goto page Previous  1, 2, 3 ... 16, 17, 18 ... 32, 33, 34  Next
Page 17 of 34
