996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Oct 04, 2018 5:36 am    Post subject: Reply with quote
CAD model has been made for the bracket which will hold the solenoid to control flow to the centre radiator.
Next job is to make it in steel.
MisterCorn
PostPosted: Mon Oct 08, 2018 7:42 am    Post subject: Reply with quote
Bracket made up for the centre radiator flow controller. The radiator brackets have been acid dipped to get all of the rubbish powder coating off them, so a load of painting ready to do now.
There were a couple of bits of rust hidden away at the back of the car behind the bumper, these have now been dealt with.
POR15 has arrived ready for going over the sections where they has been evidence of light surface rust before going over with underseal.
maldren
PostPosted: Mon Oct 08, 2018 7:57 am    Post subject: Reply with quote
POR15 is great, my 996 doesn't need it but I'm restoring my old Lotus Elan +2 and it does a great job, especially with their chassis black as a top coat where the paint is exposed to UV.
It sticks to anything and worked brilliantly on plated calipers where Hammerite completely failed to stick and flaked off.
I've also found that Acetone (used as a solvent for fibreglass resin) cleans brushes.
Mike
Mike
coullstar
PostPosted: Mon Oct 08, 2018 8:48 am    Post subject: Reply with quote
Make sure you wear gloves with the POR15 stuff. This will be a great track car once done.
2000 Audi B5 RS4
MisterCorn
PostPosted: Mon Oct 08, 2018 4:09 pm    Post subject: Reply with quote
Will do.
Various parts stripped and cleaned, ready for painting
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Oct 08, 2018 9:53 pm    Post subject: Reply with quote
I would like to come around for a nosy
kurlykris
Watkins Glen
PostPosted: Mon Oct 08, 2018 10:03 pm    Post subject: Reply with quote
+1 on that, not seen either of you for a while nooo
2006 Boxster S sport chrono
2010 Mercedes E350 AMG Sport
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Mon Oct 08, 2018 10:11 pm    Post subject: Reply with quote
[quote="kurlykris"]
+1 on that, not seen either of you for a while nooo[/quote
Better get the kettle on (no pun intended)] MC
MisterCorn
PostPosted: Tue Oct 09, 2018 6:05 am    Post subject: Reply with quote
I'm in the office until next Thursday. Just give me a shout to make sure I'm really there. Next week probably best as a whole bunch of parts are at home for painting this week.
MisterCorn
PostPosted: Tue Oct 09, 2018 6:50 pm    Post subject: Reply with quote
As last time with the rear struts, they are showing signs of rust directly from Porsche. I'll put some POR15 on them and try to get some wax in them.
The new front struts come unpainted, so they get cleaned and painted before fitting.
MisterCorn
PostPosted: Thu Oct 11, 2018 6:42 am    Post subject: Reply with quote
I masked up the outside of the car ready to attack it with the cavity wax and underseal. First job is to do the cavities with Dinitrol ML. This is a very thin penetrating cavity protector.
Before I started I went around the car and marked all of the places I wanted to inject with pieces of white tape so I knew exactly where to go. It didn’t take all that long to around the whole lot. Due to the ML being very thin it finds its way out through any other holes and seams. I haven’t done inside the rear arches or in the sills. The arches I will do from inside as the rear interior panels are currently off and it is all exposed, the sills need some welding doing when the car is off the ramp so I will get those done after the welding.
A couple of photos down the front chassis rails show that it is barely visible as it is pretty thin…
I’ll leave this for a while for any excess to drain out, then I will be going over areas which require it with POR15
Previously I had bought some Tarett top mounts but the bushes on the top were too long. I sent them back to Tarett and they changed them for shorter ones. They also supplied with a spare set of the ball joints and bushes. Not sure if that was a mistake or not though….
Unfortunately due to a change of plans I won’t be using these. So I now have a full set of freshly refurbished GT3 shock absorbers and springs with brand new Tarett top mounts going spare. I’ll either sell them or keep them in case I ever want to put them on my C2.
coullstar
PostPosted: Thu Oct 11, 2018 11:31 am    Post subject: Reply with quote
Proper job!!
Id be interested if you were thinking of selling on the Gt3 suspension.
2000 Audi B5 RS4
MisterCorn
PostPosted: Thu Oct 11, 2018 1:47 pm    Post subject: Reply with quote
I have been around all of the areas which have been treated for surface rust, plus any seams and edges I could see with two coats of POR15, ready for the wax next.
maldren
PostPosted: Thu Oct 11, 2018 1:59 pm    Post subject: Reply with quote
Are you going to paint over the POR15? I put a coat of their chassis black over it on my Lotus as POR15 is vulnerable to degradation from UV light, probably ok under wheel arches but it was a job that I don't want to repeat!
Mike
MisterCorn
PostPosted: Thu Oct 11, 2018 3:53 pm    Post subject: Reply with quote
I wasn't planning on doing. It will be covered with Dinitrol 4941 black underbody sealant and most parts will then be covered by arch liners.
maldren
PostPosted: Fri Oct 12, 2018 7:35 am    Post subject: Reply with quote
That should do the job, probably better than a thin coat of paint.
Mike
MisterCorn
PostPosted: Fri Oct 12, 2018 1:10 pm    Post subject: Reply with quote
I checked online and the Dinitrol 4941 is perfectly safe on the aluminium and rubber parts underneath the car, so I just need to keep it away from anything which will get hot. I masked up everything I could and covered most of the garage, including myself.
Just under 2 tins of Dinitrol later it looked like this:
I did most of the underneath apart from the edges near the sills which I can’t access at the moment, these will be done at a later date.
As it is all set up I’m contemplating whether it is worth doing a second coat on Monday or whether I should leave it now. I have the weekend to ponder it.
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Fri Oct 12, 2018 1:27 pm    Post subject: Reply with quote
Definitely going to town on that.
I've been doing the front seams that have a little surface rust with POR15 under my fuel tank while I have it off the car, nothing too bad again but good to be able to inspect and coat bits I have never seen previously.
Ghianightmare
PostPosted: Fri Oct 12, 2018 4:44 pm    Post subject: Reply with quote
Proper job - we’ll done. Good to see you are using a decent face mask too
2002 Seal Grey C4S
skinny_monkey
PostPosted: Fri Oct 12, 2018 8:41 pm    Post subject: Reply with quote
Loving the hat!!
Goto page Previous  1, 2, 3 ... 14, 15, 16 ... 22, 23, 24  Next
Page 15 of 24
