Why wouldn't you put a 4x4 on RR?
plynchy
13 Aug 2004
1,017
Sure I've read on here before that the C4, C4S and Turbo shouldn't be ran on a rolling road?
What are the reasons behind it? :?:
cos it will just drive off it?
Unless its a 4wd rolling road. And then your 4wd system is through a viscous coupling so will be unpredictable / might overheat and trash the coupling depending on the dyno.
AFAIK people disconnect the front propshaft on c4/s when on the dyno.
Best ask the operator of the dyno, they should know.
who told you that? nonsense
unless its a 2wd RR and you forget that and the front wheels get traction. ha ha :lol: :lol:
there are loads of good 4wd RRs around from Powerstation to Surrey RR who would take into account the car, power, toruqe vectoring and movement of power to get an accurate reading
Abbey Motorsport have a dynopack RR which you have to remove the wheels for and you then raise the car to run on the axles which the RR bolts onto.
this gives a reading at the wheels more accurately.
I thought the bigger issue for running 911's (specifically turbos) on a rolling road was the amount of fans needed to push air with the intakes on the side and the engine intake in the boot and the rads up front.
That would definately need to be considered!!!
Given that the 4wd system only diverts torque to the front if needed, if the RR has front and rear rollers which are effectively independant then a much larger percentage of torque would go to the front. I don't know if this could cause temperature issues in the viscous coupling, but I bet somebody else will....
That's along the lines of what I've read before...
Can't see it, I watched my friends 800hp Skyline in the Dyno and they had no issue cooling it.
most RR now seem to have this sorted and they know where to put the fans for cooling to mirror the wind in and over the car if its was out driving.
Some porsche specialists have custom RR for rear engine cars eg 9M in warrington.
With a 993 the 4 wheel drive can be decoupled in 15 min to allow them to be tuned on a 2wd RR, not sure if its as easy on a 996, all those water pipes may get in the way :grin:
I think you need a proper 4 wheel rolling dyno if you want to be competitive in the tuning world these days, as so many performance cars are all wheel drive ... in fact, I'd be rather put off if the dyno was only one set of rollers.
That being said, a full hub dyno would better, even if it is a bitch to set the car up. It's not like, drive on, strap down, fans on, wind up the power, adjust the parameters, print graph.)
A bit OT, bit I am setting up my turbo for more data logging, looking at different temperatures and pressures to measure turbocharger efficieenct as well as intercooler efficiency, effect of meth injection, etc. From some earlier track testing I saw a 20 degree change in inlet temperatures and over 100 degrees in front brake temperature just from changing direction of driving from headwind to tailwind. It shows the importance of a controlled environment for performance calibration and testing. All interesting stuff.
Did they have 4wd on 911s in the 60s?
Running one set of wheels for a period of time on a awd 996 mashes the dilatant fluid in the coupling, thus making it useless. Same goes for when they're brake testing on the MOT. No doubt some numpty somewhere has left the front wheels rolling on the rollers whilst testing the brakes and knackered someone's awd system without even knowing it. :nooo:
What prompted the question was a post I saw today on FB from a tuning company I use for my Cosworth, with an action pic of what appeared to be a 4x4 997 on their RR.
They have a solid reputation which is why I was surprised to see it.
Was it a Gen II? They have an electro magnetic coupling that can be disengaged.
124,551
1,441,447
48,965
renn27
