997 : 2004- 84
996 : 1997-2005 47
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
APL911
PostPosted: Thu Dec 07, 2017 6:09 pm    Post subject: Brakes complete stuck on... Reply with quote
Hi guys
Washed the 996 and put it in the garage on Monday.
Gone to get it out for the weekend and can’t move it!
I’ve give the callipers a knock with a hammer. Rocked it back and forth. It won’t budge!
Anyone else ever had this? Any advice or ideas?.... Question
pzero
PostPosted: Thu Dec 07, 2017 6:37 pm    Post subject: Reply with quote
http://www.911uk.com/viewtopic.php?p=203798&sid=9d6db43d5e9e22740b6183a437c3ab35
Not an uncommon issue. Try and take her for a spin before garaging if it has just been washed, this may reduce the dampness on the brake pads.
It's damp this time of year, which doesn't help. You could try not using the brakes and let the car car come to a gentle rest when garaging.
I oçcasionally experienced similar woes, but not when I had ceramics.
paul987
My money would be on your handbrake being stuck on.. moisture makes them stick sometimes... try tapping the rear disc bells
Ah pzero beat me to it Thumb
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
bakerboy4s
PostPosted: Thu Dec 07, 2017 7:04 pm    Post subject: Reply with quote
As PZero not unusual, pads bond to disc when damp after washing or when wet on road.
First time it happened to me there was quite a loud clang as they came free, very disturbing but no ill effects (yet)
PostPosted: Thu Dec 07, 2017 7:08 pm    Post subject: Reply with quote
I agree with all the above but would just like to point out a strange one that was similar ..
Psm kicked in on a round about and all the brakes locked on and stayed that way for 20 mins then all was fine .. untill the customer " used " the Psm again .. same thing .
Long story short theres a small rod in the master cyl that can bend ( new master cyl required ) .. the above is what happens if you use the PSM a lot !
At an Indy these days !
APL911
PostPosted: Thu Dec 07, 2017 7:39 pm    Post subject: Reply with quote
Thanks for the response. Can’t get it moving. Given up for tonight....
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Thu Dec 07, 2017 9:12 pm    Post subject: Reply with quote
Do not wash the car and stick it in the garage, this can cause loads of issues with dampness and water retention.
Do not clout your calipers with a hammer nooo
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
mr pg
PostPosted: Thu Dec 07, 2017 9:24 pm    Post subject: Reply with quote
I've had this happen and always try to run round the block first. My 996T seemed particularly bad and one one occasion took liberal use of the accelerator to free it. Bit scary as I enter my garage at an angle.
The other problem I had on that car when the PSM light came on was when I could feel the brakes being applied whilst driving, although foot was nowhere near pedal. After parking up to go shopping, on our return the car would not budge, and had to be relayed. In this instance the ABS unit failed locking the brakes on. This was not a cheap fix! At least it didn't occur when I was at speed.
kas750
Estoril
2006 Porsche 911
PostPosted: Thu Dec 07, 2017 9:48 pm    Post subject: Reply with quote
Pour boiling water on the hubs.
The thermal shock usually gets them free again. Thumb
wasz
1999 Porsche 996 Carrera 2
PostPosted: Thu Dec 07, 2017 10:33 pm    Post subject: Reply with quote
Give it some beans! and don't put it away wet...
Marky911
PostPosted: Fri Dec 08, 2017 12:14 am    Post subject: Reply with quote
I had this and it was that my bulkhead drain holes were blocked. Water had built up and got into my servo via the rod that Demort mentions.
When we got it off and tipped it up, brown rusty water poured out.
Second hand servo and unblocked my drains and all is well.
Doubt it's that though if it's only after you wash it.
My wife's old 2008 Focus had drums on the back (really, in 2008) and that used to seize all the bloody time. It used to drag the back wheels and all sorts before it freed off. I'd generally just rev it then stall it and they'd come off with a bang, but I wouldn't be so rough with my 996.
Good luck getting it sorted. It's all well and good saying wash it then drive it but if it's wet and dirty out there it defeats the point in washing it. puh
I just never put my handbrake on when it's in the garage anyway. Use a little chock of wood. .
