should one side of the exhaust be lower than the other
lechboy
12 Oct 2017
20
As in the title i was in my car at the weekend and noticed the driver side exhaust where it curves and connects to the cat is an inch or so lower than the passenger side
this is the part of the exhaust which is closest to the ground
thanks in advance any thoughts much appriciated
I would make sure that both tips are mounted correctly as a first check.
why would that make any difference these pipes bolt to the engine i think ??
if i removed the back boxes altogether i wouldn't be altering the pipes
they go from cat to engine i think
Sorry, my bad, I misread your post. If you mean the manifolds, where it goes from the cylinder head to the catalyst with three pipes on each side then might be worth checking the engine mounts to see if one is sagging. I hadn't noticed one side being lower than the other on my car.
You're engine mounts are probably goosed. Rev the engine and see them swap positions.
would be surprised only just come out of ninemiester had clutch, ims, rms,
brake pipes etc only done 500 mile but will check
So no new engine mounts then?
Bet they didn't address the knackered gearbox mount whilst the box was off either.
also gave it a good hard drive on Sunday after noticing the pipes and didn't feel any different to drive
It would be what you're used to though. That doesn't make it right, so to speak.
Worth a check.
124,559
1,441,585
48,988
Spilly67
