996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
APL911
PostPosted: Sun Dec 03, 2017 3:05 pm    Post subject: 996.2 C2 wandering steering at motorway speed. Reply with quote
Hi all. Need some quick advice.
9excellence have done a great job on my car. However at motorway speeds my steering wheel moves and wonders around just to keep the car moving straight.
I had decided to change the front and rear control arms as 9E have said the bushes are shot. It looks like a fairly straightforward job, save any seized fixings...
Could this be the cause of this? (I know it’s hard to say with this small amount of info). Or is there something else the 996 is know for that could be causing this?
9E also did a full geometry set up, replaced the front shocks and top mounts and fit four new coffin arms.
Antony
EGTE
PostPosted: Sun Dec 03, 2017 4:27 pm    Post subject: Reply with quote
If the bushes are shot, that geo. was pretty much meaningless.
It'll be geometry out of whack as the bushes allow the tyres to move about.
Change them and re-geo.
PostPosted: Sun Dec 03, 2017 4:34 pm    Post subject: Reply with quote
I'm reading it that you've had that work done.
If so, it could just be that your wheels need balancing.
EDIT: Actually reading it again I'm not sure what you've had done. Confused
If 9e did some of the work required and advised that other stuff needed doing why didn't you get them to do it Question
APL911
PostPosted: Sun Dec 03, 2017 4:45 pm    Post subject: Reply with quote
Simple. I didn’t have enough spare money to get them to do the control arms.
So I prioritised the coffin arms, shocks, top mounts and exhaust. Plus I should be able to do them myself.
cobrars
PostPosted: Sun Dec 03, 2017 5:06 pm    Post subject: Reply with quote
Could something be loose ??? try checking the top mounts or bottom arm bolts ???
I remember years ago a friend of mind had an issue similar to that (not a porsche mind you) turned out one of the bottom arm bolts was a little loose... It was tight, just not tight enough...
If it wasn't doing it before then ring 9e and ask them to check, will only take 10 mins on a ramp.
Hope you get sorted Dont know
Craig
Previous : TVR Cerbera 4.5
Current : VW Golf 25th Anniversary No 1398
Current : Porsche 911 996 C2 Manual With Full Hartech Engine & Gearbox Rebuild
Car Thread - http://911uk.com/viewtopic.php?t=118834&highlight=
APL911
PostPosted: Sun Dec 03, 2017 5:11 pm    Post subject: Reply with quote
Craig
Good point. It was doing it before. Wheels are also not balanced, but that’s not the problem. From the sounds of it, it must be the control arm bushes.
chriscoates81
PostPosted: Sun Dec 03, 2017 6:00 pm    Post subject: Reply with quote
Depending on when it happens, could possibly be Tramlining. Does it do it no matter which part of each lane you are on?
Old:1999 Carrera 2 3.4 in ocean blue with a savanna interior.
New:2002 Turbo in silver with black interior - the smile machine
paul987
PostPosted: Sun Dec 03, 2017 6:20 pm    Post subject: Reply with quote
Track rods Dont know
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
alex yates
PostPosted: Sun Dec 03, 2017 6:27 pm    Post subject: Reply with quote
If 9e have done some work on your suspension and now it's not driving right, shouldn't you just be asking them? Question
APL911
PostPosted: Sun Dec 03, 2017 6:38 pm    Post subject: Reply with quote
Good shout. I’ll change them too.
APL911
PostPosted: Sun Dec 03, 2017 6:54 pm    Post subject: Reply with quote
Not quite right. It was not driving right before it went to 9e. In their full vehicle check they recommended changing the control arms, but I could not afford it at the time. (£190+vat each). What I’m trying to figure out is if this could be the cause for the steering play and wandering at motorway speeds.
They didn’t mention the tie rods in their inspection, but they are cheap to buy and relatively simple to change out so I’ll plan to do them when I’m in there.
cheshire911
Estoril
PostPosted: Mon Dec 04, 2017 12:14 pm    Post subject: Reply with quote
It makes little sense to have geometry when there are worn suspension components. From the looks of it, you will have another geometry done when the other bits you mention are going to be fitted.
You could also consider Chris at Center Gravity - his approach to geometry is to carry out a thorough inspection of all the braking, suspension and steering components for wear and tear before doing anything with the geometry. You can be present throughout so will see first hand the state of all the bits.
Best way to contact is via their website. They may be a little far for you - they are based in Atherstone Warwickshire - I did a 200-mile round trip to have him set up my geometry and he has guys that drive from Republic of Ireland, Scotland and French Riviera to have their cars set up with his expertise touch.
Well worth it.
996 2002 X50 Turbo Manual
wasz
1999 Porsche 996 Carrera 2
PostPosted: Mon Dec 04, 2017 3:14 pm    Post subject: Reply with quote
Geo is out either bad adjustment or bushes or ball joints or mounts are shot.
Mine was all over the place on the motorway when I replaced some bits myself before I got the geo setup, even though I did my best to put things in the original place of adjustment.
2K
PostPosted: Tue Dec 26, 2017 10:24 am    Post subject: Reply with quote
Rear Sway bar bushes. For me was only noticeable at high speed, it was swaying at high speed. Get underneath back and try to pull long horizontal bar at rear of car left to right, any slight movement and there's your problem.
A previous car I brought they'd put the wrong size bush back on the car, being too large was not gripping rear bar. You don't need to jack up car, two bolts, one on each side, swap out and you're done. Find that when you start refreshing bushes, weaker ones give out once new in, but rear sway bar is where I'd start for 30 quid.
ragpicker
Estoril
PostPosted: Wed Dec 27, 2017 8:19 am    Post subject: Reply with quote
Surprised
The parts are about £80-90 each inc vat and it takes an hour to change both of them including getting the car on the lift, making a brew and painting your nails.
All garages have overheads to factor into their pricing but that seems a bit salty to me.
Its one of those jobs which really isn't that bad to DIY but as with everything it helps if you've got the right gear.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Dec 27, 2017 8:29 am    Post subject: Reply with quote
It simply sounds like you need the geo doing again as you have changed the control arms since it was last done.
APL911
PostPosted: Wed Dec 27, 2017 9:45 am    Post subject: Reply with quote
Thanks for the input guys.
It’s all done and dusted now. Car is brilliant. thumbsup
I changed the coffin arms, track rod ends and fitted lowering springs. Then I had hunter wheel alignment done to X74 geometry.
lofi
2001 Porsche 996 Turbo
PostPosted: Wed Dec 27, 2017 12:25 pm    Post subject: Reply with quote
Bit lost - what did you have done between the 9e work, the car wondering around, and the car now being brilliant. You first post said you'd already done the coffin arms. So was it the new springs and track rod ends that made the difference? Are you still running the 'shot' control arms?
LoFi
996 turbo tip
ex 944 2.5 manual
ex 964 C4 manual
996ttalot
Approved Trader
PostPosted: Wed Dec 27, 2017 12:37 pm    Post subject: Reply with quote
It was the control arms causing the wandering. It is a known cause of that and the OP explained why they were not changed.
As to the comments about pointless geo, maybe read the fact that the front shocks and top mounts were replaced - you have to do a geometry when you do that.
Any change to rear control arms will generally need a re geometry.
Ken
nineexcellence.com
Tel: 01293 226911. Follow us on Facebook www.facebook.com/Nineexcellence
SALES, SERVICE, UPGRADES
lofi
PostPosted: Wed Dec 27, 2017 12:57 pm    Post subject: Reply with quote
Ken
Thanks for clearing up - was confusing because the OP doesn't actually mention changing the control arms, just coffin arms (twice).
LoFi
996 turbo tip
ex 944 2.5 manual
ex 964 C4 manual
