Hi guys took my turbo out today for first time in 3 weeks, started up ok no white smoke no blue smoke no rattles. Pulled into shell topped up with shell premium fuel and set of home via quick run down dual carriageway.half way down oil failure light came on,in dash,oil pressure dropped to almost one then went up to five,I immediately pulled over and checked engine for leaks etc.luckily I was only one 1 mile from home.i couldnt see any leaks or drips on road,I did the oil level check and level came up to the right bar on the dash and I have check engine light take car to nearest service centre on clocks.anyone had this issue and what should I be looking for.
Reason I'm asking for help guys is it's a long drive to my preferred Porsche car care centres ( if you know what I mean)
