997 : 2004- 85
996 : 1997-2005 46
993 : 1993-1998 6
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
mollytherocker
PostPosted: Wed Oct 25, 2017 8:35 pm    Post subject: Wheel Arch Stone chip protection film? Reply with quote
Hi
Anyone used this kit? Any good? Any other recommendations?
I just had a bit of paintwork done and would like to protect these areas!
https://www.ebay.co.uk/itm/Porsche-911-993-CLEAR-Wing-Bumper-Arch-Stone-Chip-Guard-Paint-Protection-Film/132151175755?hash=item1ec4d2ea4b:g:w4QAAOSw7NpZ25pW
cableguy
PostPosted: Wed Oct 25, 2017 8:55 pm    Post subject: Reply with quote
Seems a no brainer for £19.00 Thumb
Discussed here but unfortunately photobucket pics are no longer: http://911uk.com/viewtopic.php?t=121840&highlight=helicopter+tape
C.
Pork!
MJA911
2012 Porsche 991 Carrera
PostPosted: Wed Oct 25, 2017 9:31 pm    Post subject: Reply with quote
Just had a little paintwork done on mine for this very reason (stone chip/rash) so will give this a go, would be good to keep it tidy around the arches Thumb
PH5121
PostPosted: Thu Oct 26, 2017 6:25 am    Post subject: Reply with quote
I've just had my rear pu painted so will try a set of those too.
I had a set of 944 clear front wing protectors on before, they didn't fit great but did a job, these look like a better solution.
kerb scraper
1997 Porsche 993 Carrera 4
PostPosted: Thu Oct 26, 2017 11:26 am    Post subject: Reply with quote
OK - reinstated the photos using Imgur.com (been meaning to do that for a while), so Cableguy's link now shows the pics.
Those eBay films look a bit odd in the diagrams? Almost as if they are fitted to the wrong end?
Shape of the rear one looks similar to those I made for the fronts?
Make sure you have a nice warm environment for fitting the film as it needs to be flexible.
1997 C4 Cabriolet, Arctic Silver, black interior, 18" hollow spokes, Bilstein PSS10s, RSRs, 200 cell cats, Mobil 1 sticker, LED to interior. Bergville t-lights.
PTT
PostPosted: Thu Oct 26, 2017 3:34 pm    Post subject: Reply with quote
You can also put
~original
behind jpg and the photo is visible again
2002 996 GT2
1993 964 Turbo 3.6
1980 924 Turbo
1977 924 in progress for the ultimate roadtrip in 2020 Amsterdam Beijing
1983 924 for the roadtrip
mollytherocker
PostPosted: Fri Oct 27, 2017 9:35 pm    Post subject: Reply with quote
Thanks all, if you try these, let me know how you get on!
mollytherocker
PostPosted: Mon Feb 26, 2018 8:43 am    Post subject: Reply with quote
Hi
Finally got around to fitting this clear protector kit I got off eBay. Well worth it to protect the vulnerable stone chip areas on a 993. I had to reshape the front ones as I didn't like the fit, but the rears are good. However, the rear ones don't go right inside the PU, so I added a couple more cut pieces. Overall, at £19, not a bad kit.
I need to drive it now!
 Filesize:  102.51 KB
 Viewed:  2050 Time(s)
 Filesize:  146.61 KB
 Filesize:  62.88 KB
 Filesize:  83.81 KB
 Filesize:  50.2 KB
 Filesize:  143.53 KB
kerb scraper
PostPosted: Mon Feb 26, 2018 12:15 pm    Post subject: Reply with quote
Looking good there.
Did you just stick them on dry? Must be tricky.
(And very brave to fit them in the cold weather; I think I did mine on the hottest day of the year)
mollytherocker
PostPosted: Mon Feb 26, 2018 7:15 pm    Post subject: Reply with quote
kerb scraper wrote:
Looking good there.
Yes, did dry. Just used the hair dryer to heat them up first so that they would stretch a little.
mollytherocker
kerb scraper wrote:
Looking good there.
AP90
PostPosted: Tue Feb 27, 2018 1:39 pm    Post subject: Reply with quote
Your old bus looks really great, well done on the job too
