996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 17
Cayenne : 2003- 7
Macan : 2014- 3
912-914-924-928-944-968 3
MattyR
PostPosted: Mon Sep 04, 2017 4:28 pm    Post subject: Front wipers - it all goes a bit limp wristed Reply with quote
Navigating the deluge this morning and the driver's side wiper suddenly throws a wobbly, stops working in tandem with it's best mate and promptly has a little rest. Permanently.
I'm assuming it's not the motor which no doubt means it's some annoying £600.00 clip or some such? And naturally will require 15 hours labour plus the engine out to be rectified. Yep thought so.
Any ideas?
1994 Aventura Grün C2 993
sday12
PostPosted: Mon Sep 04, 2017 6:36 pm    Post subject: Reply with quote
Relay?
1997 Schwartz Black Manual 993 Carrera 2S Hardbacks/Hollow Spokes + Tequipment goodies
dommorton
1998 Porsche 993 Carrera 4S
PostPosted: Mon Sep 04, 2017 6:40 pm    Post subject: Reply with quote
Could be way simpler and just be the nut on the spindle that's come loose.
Flip the plastic cap up and check the nut for tightness.
Good cars can get you from point A to point B. And great cars? Well, they'll just get you into trouble.
madalaa
2009 Porsche Boxster (987)
PostPosted: Mon Sep 04, 2017 11:08 pm    Post subject: Reply with quote
....... yeah that .......
Allan E
PostPosted: Tue Sep 05, 2017 11:14 am    Post subject: Wipers Reply with quote
Hopefully it is just that but it may be the connecting mechanism has failed. The drive arm extends from one wiper to the other with various pins, possibly one has sheared and hence loss of movement.
PostPosted: Tue Sep 05, 2017 1:39 pm    Post subject: Reply with quote
Hand No excuse for loose nuts. Just hope the splines aren't knackered. Is the widget present Dont know
So far you're the only person to have used the wipers in anger except the MOT testers to check the washer jets Grin
MattyR
PostPosted: Tue Sep 05, 2017 2:09 pm    Post subject: Reply with quote
Cheers gents I'll give the wiper nut a go. The linage sounds very plausible as I've just taken a look at the PET diagram.
Ta!
PostPosted: Tue Sep 05, 2017 2:53 pm    Post subject: Reply with quote
Thumb Those wiper nuts need to be as tight as a monkey's foreskin what
MattyR
PostPosted: Tue Sep 05, 2017 5:19 pm    Post subject: Reply with quote
Alas I have no monkey to use as a reference, but tight my nuts shall be!
The widget is indeed in-situ. However non-standard Bosch wiper blades mean that it needed some coaxing to fit Surprised
And as for using my wipers, well I can practically hear the sharp intakes of breath as fellow 933 owners read those words. Shocking.
dommorton
PostPosted: Tue Sep 05, 2017 5:30 pm    Post subject: Reply with quote
Used mine in torrential rain Sunday coming back from Classics at the Castle Surprised
madalaa
PostPosted: Wed Sep 06, 2017 9:44 am    Post subject: Reply with quote
........ Dom is still in recovery mode ...... Floor
dommorton
PostPosted: Wed Sep 06, 2017 5:53 pm    Post subject: Reply with quote
Car still dirty in the garage Surprised
It is at least dry as the dehumidifier sorted that
str12
PostPosted: Wed Sep 06, 2017 7:20 pm    Post subject: Reply with quote
Had your windscreen replaced recently? Autoglass et al do not correctly tighten wipers after replacing glass in fear of damaging prestige cars, apparently.
