996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Macan : 2014- 3
paul987
PostPosted: Sat Sep 02, 2017 4:23 pm    Post subject: Front Camber adjustment Reply with quote
OK so I've been replacing my coffin arms... I had a seized nut on one so the joint just kept spinning...after prying on it... and getting a jack under it to try to stop it spinning in the end I had to cut it off...
But now as I Reassemble it... the camber seems to be out.. so I can't get the new one in Question
I wonder if I've bent something jacking it up Dont know or could I have spun the spring some how and altered the camber Dont know
Any ideas is greatly appreciated Sad
"Strong minds discuss ideas average minds discuss events, weak minds discuss people. Strong minded people discuss ideas to solve problems." -Socrates
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
Demort
Estoril
PostPosted: Sat Sep 02, 2017 4:46 pm    Post subject: Reply with quote
Front or rear ?
Do you mean the nut on the ball joint span so you cut that off and thats the part you cant get back in .. the ball joint or do you mean the bolt holding the arm in place that also adjusts the camber ?
Any pictures Smile
At an Indy these days !
paul987
PostPosted: Sat Sep 02, 2017 5:01 pm    Post subject: Reply with quote
Ah pictures Laughing only of the offending nut
Coffin arm ball joint on the front
paul987
PostPosted: Sat Sep 02, 2017 5:15 pm    Post subject: Reply with quote
Demort forgot to add...
Well to be honest I tried it the bolt to the chassis first couldn't get the ball joint in.. so tried it ball joint first still couldn't get the other end in.... I couldn't see any adusters on the chassis end.. I have read about them but cant see them Laughing thanks Thumb ñ
Demort
Estoril
Ok .. front camber is adjusted at the top of the strut , its a C4 ( driveshaft still connected ) and the new ball joint will be very stiff , you also still have the track rod connected so i think your not pulling the hub / disc out far enough , you also have to move the ball joint a bit to position it .
If the arm is still off then just insert the ball joint end .. that will prove theres nothing stopping it going into the hole .
Them try and pull out the hub further or remove the track rod end to help .
If none of this works or your still not sure then ill pm you my number .. talking is often easier to explain things than on here .
Demort
Estoril
PostPosted: Sat Sep 02, 2017 5:18 pm    Post subject: Reply with quote
PMed my number Smile
Demort
Estoril
PostPosted: Sat Sep 02, 2017 6:22 pm    Post subject: Reply with quote
One other thing i forgot to mention .. if you still have the drop link connected then remove that at the roll bar end , that will also help you as you only have the driveshaft holding it at that point .
paul987
PostPosted: Sat Sep 02, 2017 7:26 pm    Post subject: Reply with quote
Will do Demort Thumb many thanks once again... I shall return with the results Laughing
paul987
PostPosted: Wed Sep 06, 2017 9:06 pm    Post subject: Reply with quote
Well I finally got it all sorted today (Thanks to Demort's telephone advice service Laughing ) There was a slight delay due to me snapping my ball joint extractor on the track rod Embarassed
Thanks again I'm Demort Thumb
Marky911
PostPosted: Wed Sep 06, 2017 9:28 pm    Post subject: Reply with quote
Good result! Satisfying once it's all back together. Thumb
Kudos to Demort, especially for handing your number out. With some of the folk on here I'm surprised you don't answer to heavy breathing and questions about what you're wearing. Not the OP of course. Wink
Seriously though, good stuff.
Demort
Estoril
PostPosted: Thu Sep 07, 2017 6:38 pm    Post subject: Reply with quote
Some times its just easier to explain things in a phone call and not try typeing it all out .. plus im crap at explaining things this way lol .
Got me thinking about the heavy breathing though .. next time ill let the wife answer the phone !
Aww ball join tool .. i use an airgun but sometimes they are dam tight so you do it up / gun it up till its feeling pretty dangerous then stop .. wait a few mins and it will often let go .. if not clought it with a good old hammer .. many times ive felt like my ball joint splitter was about to break so thats what i do.
Yea i know its too late now but other people read here as well Very Happy
Good result though young man Thumb Kudos .
