996 : 1997-2005 50
993 : 1993-1998 6
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 15
Cayenne : 2003- 9
Macan : 2014- 1
markturner1960
2003 Porsche 996 GT3 Mk2
PostPosted: Sat Aug 26, 2017 3:42 pm    Post subject: Battery dead, advice please Reply with quote
OK, as thread title, went to open car today in the garage and it would not unlock on the key button. It's been approx 3 weeks since I last used it and was behaving fine then.
Immediate issue is that I cant open the frunk - I manually unlocked the doors with the key, but the frunk and boot releases do not appear to work ( I assume they are powered by the battery or linked somehow in that case? )
I also saw something on the fusecover that would indicate bonnet release, but could not figure out how to do it....
Can someone advise please? Whats the best way to test a battery, would Halfords do it if I remove it? And is replacement straightforwards or does it need coding etc like in a BMW?
996 Mk2 GT3 Speed yellow
Shanghai
PostPosted: Sat Aug 26, 2017 3:46 pm    Post subject: Reply with quote
Have a read here ..
http://911uk.com/viewtopic.php?t=56267
Jump pack on the fuse board terminal is the normal way to open the bonnet .
Battery will need to be recharged and then tested .. any garage can do this .
At an Indy these days !
markturner1960
PostPosted: Sat Aug 26, 2017 7:18 pm    Post subject: Reply with quote
Excellent, thanks!
NXI20
Paul Ricard
2004 Porsche 996 GT3 Mk2
PostPosted: Sat Aug 26, 2017 7:24 pm    Post subject: Re: Battery dead, advice please Reply with quote
I'd be hooking the battery up to a CTEK charger and let it do its reconditioning cycle.
If that doesn't revive it, time for an 096 Bosch S5 battery, particularly if yours is currently a Moll, which are notorious for dying within a couple of years.
Changing the battery is simple: drop the drivers window all the way, leave the key in position 1 and disconnect the battery. Reconnect the new battery & then turn the ignition off. Putting the window back up with the door shut will tell the sensors where the top is. No coding is required but you'll need to reset the clock.
Nick
1978 Carrera SC Barn Find in Red (restoration project)
