Ocean996C4
- Joined
- 14 Jul 2016
- Messages
- 134
Good afternoon, I'm a long term 996 owner having had several, normally in 4wd flavour, but I've not had the issue that I'm having with tyres on my current car before.
It's a 1999 C4 without a LSD, it's on coilovers, new coffin arms all round, had a four wheel alignment done before fitting a new set of Pirelli P zero tyres all round.
1800 miles later and both rear tyres are goosed, road driving only, no track days and not what I'd call particularly spirited driving.
I've been running 34psi front and 40psi rear which is a bit lower than standard, the tyres have worn fairly consistently across the width of the tyre.
Any thoughts on a possible cause for the accelerated wear?
Thanks is advance
Thanks is advance
