C11BRA
- Joined
- 30 Mar 2015
- Messages
- 1,063
Hi chaps.
Ever since owning the car, there has been a slight knock from the front suspension. Most common over slightly uneven surfaces or when one wheel changes height, say straddling a raised manhole even at slow speed. Exactly what I would expect from antiroll bar links.
When I did the initial overhaul I replaced the front antiroll bar links, convinced this was the fault.
Has any one changed these on a C2 (C4 are standard type)? Mine were fused into the knuckles. I ended up drilling the old ones out. 4 hour job from a 20 minute job. You can imagine my disgust when the noise was still there!!!
It's been on a ramp numerous times, even at a specialist but no play can be found.
I have ordered a set of genuine D rubbers (antiroll bar bushes where it meets the chassis). Normally I would not even consider these but I suffered for 4 years in my Subaru with a similar noise, only to replace the D rubbers, fix the noise, 1 month before selling it. Grrrrrrr.
I didn't fit genuine links so I'm not counting these out completely. Any recommendations? (Budget conscious as always with C11BRA)
Might disconnect the links & go for a drive.
Just makes the cars feel more tired than it is.
NB. You can hear & feel the knock through the floor/pedals. Very subtle, passengers don't notice.....but I do.
