996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Macan : 2014- 3
B19KER
2002 Porsche 996 Carrera 4
PostPosted: Mon Jun 19, 2017 6:09 pm    Post subject: 911 996 just dropped it water Reply with quote
Evening all my 911 has just dropped slot of water shortly after leaving the house.
The water is coming from the back of engine above the offside exhaust just to the right of centre.
Engine has no miss fire and only warning light is coolent low.
Any thoughts
J U S T L I V I N G T H E D R E A M
Demort
Estoril
PostPosted: Mon Jun 19, 2017 6:12 pm    Post subject: Reply with quote
N/s/r is the coolant tank and water pump .. o/s/r and i can only think of x1 hose there .. needs airbox removed and have a look i think.
At an Indy these days !
B19KER
PostPosted: Mon Jun 19, 2017 6:17 pm    Post subject: Reply with quote
It is under the air box you can't see either from above or below. It looses all the water you put is straight away.
No cold water added to system. Car awaiting AA
It had only drove three miles and there was no temp change
Demort
Estoril
PostPosted: Mon Jun 19, 2017 6:28 pm    Post subject: Reply with quote
It sounds like a coolant pipe has let go if its looseing water that quickly , theres one main one each side but it sounds like its going to be a recovery job either way im afraid .
Both coolant pipes are inline with the base of the airbox so in the right place .
