996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Macan : 2014- 3
Nattyboy
PostPosted: Sun Jun 18, 2017 10:53 am    Post subject: Help - removal of side mirrors from triangles Reply with quote
Hope someone can help - I am replacing the outer ring triangles but can't figure out how the mirror comes away from the black plastic triangles part. I've searched but can't find anything ? Cheers nat
2010 987 Spyder (replacing 997 C4S Aero kit)
2006 BMW X3 M Sport
2010 Fiat 500C
Nattyboy
PostPosted: Mon Jun 19, 2017 4:11 pm    Post subject: Reply with quote
Anyone -? I'm stuck lol !
2006 BMW X3 M Sport
2010 Fiat 500C
Demort
Estoril
PostPosted: Mon Jun 19, 2017 6:08 pm    Post subject: Reply with quote
Im not sure which bit you mean im afraid .. do you mean the outer triangle thats part of the mirror ? if so that holds the brackets and is basically the main part of the mirror .. glass out mirror off then its a case of undoing every screw you can see along with a few clips on the panels.
Any chance of a picture of what you mean ?
I think the lack of replys might be as no one quite understands which bit it is Smile
Secondly i take it your no where near Brighton are you ? no one ever seems to be near me Sad
At an Indy these days !
edge
PostPosted: Mon Jun 19, 2017 6:14 pm    Post subject: Reply with quote
I wasn't sure what he meant either so I took a stab at it by posting a link to a video on his other post , may help to move forward Surprised
Sold 2004 Boxster S
Sold 2006 997S
Sold 2008 GT3
Sold 2009 Boxster S
Sold Red 2013 981 S
997 Gen2 Turbo
Demort
Estoril
PostPosted: Mon Jun 19, 2017 6:16 pm    Post subject: Reply with quote
Good call young man .. anything helps .. like a picture OP cough Very Happy
Nattyboy
PostPosted: Mon Jun 19, 2017 11:01 pm    Post subject: Reply with quote
Apologies for the lame post guys ! It's the outer triangles I'm trying to separate - haven't got a clue where to start and there's nothing I can find on the tinter web ! How do you take the glass off ? Thanks for the replies - appreciated.
2006 BMW X3 M Sport
2010 Fiat 500C
Demort
Estoril
PostPosted: Tue Jun 20, 2017 5:58 pm    Post subject: Reply with quote
I assume this is so you can paint it ?
If you are replaceing it then the new part will help you a lot here as you can see the fixings .
The mirror is pushed on .. its a plastic trim tool a bit of leavering and a certain amount of praying to get it off with out breaking it .
Try levering either top or bottom of the glass .. not at the sides ..and im not responsible if it breaks .
Once off then undo the 4 screws holding the motor on and unplug the harnes .. you can then see other screws in x2 metal bars , these are part of the triangle bit .. undo them and ones holding the cases on .. you can see the fixings basically .. its then a case of removeing the outer plastic covers and the wireing .
Might be best to take a few photos as you go , you might need them on rebuilding it .
If it helps then its worse than it sounds lol .. nah its not too bad but just dont force anything , if stuck then photo and post it so i can see were you are with it.
Its actually about 1hr to remove strip and rebuild at a garage .
If you just mean the triangle and its 2 seperate parts then i have no idear as ive never tryed im afraid but post a photo of the inside and it might jog the old memory Very Happy
