Boba fett
- Joined
- 14 May 2015
- Messages
- 2,685
Just had a full service and full inspection done as I do yearly, and it just goes to show, its better to use these cars.
They could not bleed the brakes as the bleed nipples are all seized and I now have a snapped one (going back in for these to be released and the snapped one drilled out. I have some surface rust on bolts and clamps and a couple of brake pipes underneath that I am having addressed.
Must use it more.
Most annoying, one tyre pressure monitor is now not working, as apparently they have little watch battery's in them and mine is flat ? can these be coded out?
Must use it more.
