My clutch feels pretty heavy and on/off so i think it needs replaced. It doesn't ver slip though, but I have no record of a change at 130k.
Looks like the going rate for a clutch change at indy is £650ish
That will be +RMS and IMSB cover for me and likely +flywheel (£400) as its never been changed at 130k.
Also best to change this lot whilst its out and do a proper job:
Throw-Out Bearing Guide Tube
Flywheel Seal
Clutch Release Lever to remove creaks
You can get a scissor lift type transmission jack for under £100 and a sachs clutch and luk flywheel for £532.
Has anyone got any cheerful success stories about changing the clutch on your drive, alone on your back?
I once swapped the gearbox on a Peugeot 306 alone, how hard can it be? Wish me luck....
Flywheel Seal
