Porsche 911UK Forum
Recommend me a good low profile trolley jack
searider
Well-known member
7 Feb 2013
145
Afternoon All,
I need to get one of the front wheels off my car and find that my Halfords 2T trolley jack won't fit under the jacking point.
What can anyone recommend?
Duncan
You could always try the trick of driving onto a piece of board to gain you the extra ground height.
I have a Halfords low profile jack that just about goes under my 997 C4S.
Andrew
Cheers, I'm M030 too!
Andrew
I did think about driving onto a piece of board. You'd think with the amount of c**p in my garage there would be some handy - but no luck!
I've also just purchased an SGS one. I think it was around 39 pounds. Very pleased with it so far.
Just don't do what I did and get the one with castors instead of the roller (roller is lower).
I have been using the aluminium low entry jack from machine mart for the last two years for work and its been fantastic..
Bit of scaffolding board is ideal
Use it when I swap the summer/winter wheels on my wife's BMW 1 series
I have an Arcan low profile. Very robust.
Can you get the jack under the rear jacking position? If so just jack the car up from there instead. Both wheels will lift off the floor.
Mine doesn't although I guess it depends on how high you Jack it.
+1 for the SGS jack ...I have a 2.5 ton version and it copes with my Cayenne and my Turbo so plenty lift height but also good clearance to place the jack in under the car to the jacking points .......
Good manoeuvrability with roller at front and castor wheels at the rear ......good control on the hydraulic release too......
Terry
I have a Clarke jack, the best buy from Auto Express Clarke Strong Arm 2.25 Tonne Low Profile Trolley Jack CTJ2250LP, it's fine for my M30 suspension 996.2 and good value. You get them from Machine Mart.
Looking at some turbos on Saturday, they can be seriously low!
Mike
124,358
1,439,470
48,716
993gtnut
