997 : 2004- 74
996 : 1997-2005 43
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Pip1968
PostPosted: Fri Mar 31, 2017 9:33 am    Post subject: Porsche Cup Steering wheel - assembly? Reply with quote
Pretty much as titled. I bought a Cup steering wheel from Gert at Carnewal (gret service). It is something I have been thinking about for a while. That or a refurbishment of the OEM one. Mark Turner's thread gave me a gentle reminder.
Anyway it arrived yesterday and it comes in a few more pieces than I thought. Dont know Anyway I am happy with the airbag side of things (I think). Just solder the resistor across the connectors for the connector.
What I would like to know is in what order the bits are attached to the column. Ensuring you mark the centre point seems to be key as well as key to position 1 and disconnecting the battery for 20 minutes before starting work. I have read the how to do its on here although some pictures are missing and neither explain in laymen's terms the order of fitment.
I have attached pictures in the hope that someone can give further direction. I would like to get it done for my drive to the meet at Porstmouth with Total911 on Sunday.
Pointers welcome.
Pip
I am not sure where this aluminium metal plate fits but have guessed at against the wheel. It has a connector on it.
 Filesize:  819.2 KB
 Viewed:  4127 Time(s)
This came with a little metal clip/ring which I assume just keeps the horn button in place on the wheel and have therefore inserted it into the plastic clips
 Filesize:  906.68 KB
 Viewed:  4131 Time(s)
This is what I think the order of fitment is with the small catch presumably straing onto the steering wheel column. I assume the pin fits into something on the column.
 Filesize:  914.14 KB
 Viewed:  4133 Time(s)
Diggermeister
PostPosted: Fri Mar 31, 2017 10:59 am    Post subject: Reply with quote
Pip, I'm afraid I don't have the answer but I'm watching/bumping this thread because this is something I'm very interested in.
And good luck with it!
NXI20
Paul Ricard
2004 Porsche 996 GT3 Mk2
PostPosted: Fri Mar 31, 2017 2:17 pm    Post subject: Reply with quote
Your assembly order is correct. The centre thing I don't have & looks like a spacer to me? I have a removable wheel though & that brings it closer.
It's really pretty obvious once you take the old one off though.
Nick
1978 Carrera SC Barn Find in Red (restoration project)
Stuart
PostPosted: Fri Mar 31, 2017 2:28 pm    Post subject: Reply with quote
As per Nick, you won't need the spacer.
Roro
PostPosted: Fri Mar 31, 2017 5:31 pm    Post subject: Reply with quote
Is this wheel going on a 996 or 997? I bought the same wheel from Gert, which is a 996 wheel, and was assured it would fit my 997. It does... with a bit of ... modification
2007 997.1 GT3
2016 Smart ForFour
2009 BMW X5 30d
Pip1968
PostPosted: Fri Mar 31, 2017 8:02 pm    Post subject: Reply with quote
Thank you Nick. I was beginning to think that all the tinkerers were away on track days Smile .
So the thick ring piece (12mm thick -see picture) is a spacer that I will not need. Well at least that is something I will not have to worry about.
Roro, mine is a 996 so hopefully I will not have any issues or need to modify. What did you need to do to your to get it to fit?
Well hopefully I will have a successful tinker tomorrow.
Pip
Not required.
 Filesize:  184.38 KB
 Viewed:  4034 Time(s)
Senoj
PostPosted: Fri Mar 31, 2017 10:00 pm    Post subject: Reply with quote
You just need some finger extensions now so you can reach the indicator stalk Very Happy
Roro
PostPosted: Sat Apr 01, 2017 7:11 am    Post subject: Reply with quote
Pip
From memory it was one of the little black bits that stick up around the edge of your second pic. One of them had to go but other than that it was quite an easy fit. It was actually Matt @ Porschacare that fitted mine. The steering wheel didn't align correctly (the holes weren't in exactly the right place and had to be ever so slightly off centre to drive in straight line), but Centre Gravity fixed that for me through the geo last weekend
Senoj - it's not actually that bad - and then not an issue at all since I remembered the steering wheel adjusts for reach (on the 997, don't know about 996) Grin
2007 997.1 GT3
2016 Smart ForFour
2009 BMW X5 30d
NXI20
Paul Ricard
PostPosted: Sat Apr 01, 2017 10:03 am    Post subject: Reply with quote
You have fitted the wrong wheel for the 997 Roro Wink
It should be a flat OMP wheel, not a dished Momo. Pip has the correct (and nicer imho) wheel for a 996.
Nick
pye21
PostPosted: Sat Apr 01, 2017 10:38 am    Post subject: Reply with quote
I have just done this, it's more in depth than you think and the instructions from gent are incomplete.
When you pull the swishing steering wheel off you need to remove the norm ring below that also and unplug this back at the connectors. One of the connectors is the airbag, orange I think. This needs your resistor soldering across them.
You then need to solder a plug onto the horn live, which is one of the cables on the other connector. The live is the brown cable. You need a female bullet connector that will plug into the pin on the back of the 964 spring horn connection. To plug this in, you need to break off a tab on the plug that sits behind the column to the RHS. Should be obvious where, the connector only fits in the column one way.
You will then plug the connector in, sit the boss on, should be marked as top so be careful when removing your wheel. Then you need the thin ring, then the wheel itself. 12mm spacer can be fitted between the boss and thin ring. The centre cap goes on next and plugs into the cable from the boss. There is no cable plugged into the thin ring and Gert will have sent you an earth cable that is t needed. That is used on other types of centre cap that have a second connection for an earth, the Porsche one earths through the thin ring using a wire on the cap.
Make sure you do all the electrical connections with the battery disconnected and only put it back on once your complete.
pye21
PostPosted: Sat Apr 01, 2017 10:43 am    Post subject: Reply with quote
I have a document written in word with some pics that I could email to anyone if my post doesn't make sense.
I bought a bag of 100 connectors for my horn connector so have plenty and I even have another airbag resistor soldered and heat shrunk into a plug if anyone needs that.
Roro
PostPosted: Sat Apr 01, 2017 11:01 am    Post subject: Reply with quote
Yes so you've mentioned to me before Smile
It's "wrong" insofar as it's not a direct plug n play replacement, but I agree it looks far nicer than the OMP wheel which is why I went for it. Although as we've seen it's not a simple replacement for 996 either. The 997 'reach' issue is solved simply by adjusting the wheel so the rim is further away from you and closer to the stalks/dash. So I'd need to see Cunno's wheel for instance to compare distance from the dash, but I don't think mine is that much further away than his OMP wheel
2007 997.1 GT3
2016 Smart ForFour
2009 BMW X5 30d
Pip1968
PostPosted: Sat Apr 01, 2017 4:52 pm    Post subject: Reply with quote
Well over 45 mins f'...ing around and I am at present a broken man. I have not even hit first base in undoing the two T30 screws on the rear of the OEM steering wheel. Not only is it bloomin' awkward to line up the torx key but when I do I think they have been torqued like wheel nuts and they just won't budge. I am now toying with paying for Porsche to undo the screws for me and then giving it back to me to finish.
I hate quitting and would rather stay up to the early hours than surrender to the Germans PC Wall Gun Fire Gun Fire Wall WTF
I am worried that continuing will make the situation worse in rounding the screws.
Pip
"Yellow surrender monkey"
Senoj
PostPosted: Sat Apr 01, 2017 9:07 pm    Post subject: Reply with quote
Pip
Is this just to get the airbag off? Isn't that the easy bit Floor
Sorry, not much help...
Pip1968
PostPosted: Sat Apr 01, 2017 9:41 pm    Post subject: Reply with quote
Well shortly after my post and total annoyance I tried an 3/8 wrench with the T30 on the end (instead of a T30 bar or the screwdriver option) and got the bag off but became stuck again as to what else needs removing. I shall attach two more pictures of possibilities but will bang the wheel back on tomorrow and go to Portsmouth and use local knowledge Very Happy . Here is hoping.
I sort of assume that the black cassette needs to come off so that the tab on the 'neck/extender' has somewhere to sit.
Pip Question Question Question
Ps No2 photo is actually the pre position to No1 although posted in the wrong order - you will see the 24mm nut still in place.
Removing further items I am stuck as to whether this black cassette needs to be removed too or not?
 Filesize:  723.99 KB
 Viewed:  3861 Time(s)
So I got to this stage and then went to the next - too far???
 Filesize:  608.03 KB
 Viewed:  3864 Time(s)
pye21
PostPosted: Sun Apr 02, 2017 2:27 am    Post subject: Reply with quote
Yes the casette needs coming off. You also need to remove the plastic surounds. There is a t20 fixing either side that will undo them and allow them to be removed.
Pip1968
PostPosted: Sat Jun 03, 2017 11:10 am    Post subject: Reply with quote
Well yesterday I finally got around to completion of this modification. Whilst it looks good (as well as the weight saving Wink ) the horn is not playing. I have ascertained that the modified connectors are all good as far as the L shaped connector but it don't think it is connecting with the central boss (third picture in my first post - L connector and boss).
Do I need to shave something off from the bottom of the protruding tab on the boss to ensure the L connector touches and completes the connection with it????
Ps Thank you very much to Pye21 for emailing me some instructions. Gert did not send me anything with the kit although he does normally and did answer my query regarding the earth connection which differs from Pye21's instructions.
Stuart
PostPosted: Sat Jun 03, 2017 12:47 pm    Post subject: Reply with quote
Try bending the brass connector back, this is what I had to do.
Pip1968
PostPosted: Sat Jun 03, 2017 7:34 pm    Post subject: Reply with quote
Brilliant Stuart phase one complete but for some reason I am not getting the earth from/through the steering wheel. I am wondering whether I need to remove the silver shim as the connection is made by the brass wire on the side of the horn button connecting to the boss/shaft.
This is driving me crazy.
Pip
pye21
PostPosted: Mon Jun 05, 2017 8:27 pm    Post subject: Reply with quote
You need the silver shim, it is the fit for the centre button.
Where did you connect the cable from the boss to? The button or the silver ring?
Check the brass wire on the button is seated correctly.
This may seam like a silky comment, but you need the ignition on for the horn to work.
