Porsche 911UK Forum
Removing C4 front shock absorbers
Boardsi
Member
18 Jan 2017
12
My front C4 top mounts are shot and need replacing, it even looks like they are rusted to the shock absorber shaft when viewed from below.
I had read somewhere that you can remove the C2 shocks without undoing the 32mm hub nut but this is not true on the C4?
any help appreciated as I will be doing on the drive....
I removed my C2 shocks from the hub without the need to remove the hub, I just removed what I could to let the hub go as low as possible and I was able to bring the strut out over the top. I'm not sure if this would be possible with a C4 but you wouldn't need to remove the driveshaft if you could? You would still need spring compressors to shorten the length.
I changed my C4 top mounts with spring compressors. No need to remove from the hub.
Just had the front springs changed on my 987 & was advised that in some instances the shock absorber rusts itself onto the top mount bolt. Wasn't prepared to sink further money into have the shocks replaced as well so a few days before the work was started i soaked the top mount bolt / thread with Plusgas after taking a wire brush to the thread. Did this every night for a few days & had no problems.
124,358
1,439,494
48,717
Atlas.997
