Have a friend looking at an early 996. He is concerned over the car he has looked at has a little rust bubble appearing on the rear arch.
Have any others on here experienced any rust issues on a 996.
Thanks in advance. Cheers Al
Very very common. Don't worry about it, but obviously check all other panels are original. Look for under bonnet sticker and factory seams where rear quarters meet the rear panel.
They're getting to that age where stone chips on arches are developing into rust bubbles. Usually very slow growing. Most cars look like they've been shot blasted where the front arches meet the side skirts. All just normal signs of use.
When I had my 993 in getting scuttle done there was a 996 which I was shown that had a new piece of metal welded into rear arch after what started as just a bubble! It then needed rear quarter painted so don't just assume it will only be a £100 to sort mate!
It all depends on whether the rust is coming through from underneath, in which case this would point to a poor previous repair, or top down from a stone chip or the like. The latter will be relatively straightforward and inexpensive to sort out but rust resulting from a poor previous repair could be expensive.
Thanks Al for posting this question. The rest of the car seems fine body wise. I think I just be wanting an spotless car for my money. I'm just so fussy at times.
Nothing wrong with that. Welcome to the forum. In my experience there is often little in price between cars in good condition and those in poor condition, so holding out for a good one is a smart move.
The rear arches are the first places that rust on the 996, I noticed the seam between my inner and outer skins had a little rust developing so I stripped it back, sealed it and made good before it started to get any worse, it's looked fine for a couple of years now but it is one place to watch for 996 owners and if you can nip it in the bud now you will save a lot of expense in the future.
Yep - 996s aren't made out of vibranium or anything, ultimately they will rust the same as anything else, they're just better treated than most in the first place(!) - my 996 will be 20 years old next year and will have covered close to 225,000 miles
I've had one arch cut out and new metal welded in (nearside). At some point the same will ultimately be required on the offside.
Note: worth having a look at the "sandwich" seams on the edges of your engine cover/decklid and bonnet - these will ultimately start to go as well.... and maybe don't ever look underneath your car if you are this squeamish........
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
