I have an upgraded amp and head unit in my 4S. The amp was fitted by a previous owner, and I've changed the head unit.
There is a quiet whining noise from the speakers that rises and falls with the engine revs. Its amusing for a bit, but gets on my nerves sometimes!
I think its the amp as it did it with the previous head unit too. The noise does not change in volume with the volume control, and only stops when you fully turn off the head unit.
Is this likely to be a nightmare to sort, or relatively straightforward?
