997 : 2004- 63
Boxster : 1997- 27
Marky911
PostPosted: Wed Jun 21, 2017 8:03 am    Post subject: Reply with quote
Quick update but nothing meaningful.
I had an issue with one of my keys dying a month or so ago. A look through the history file and sure enough they weren't that old. Receipt was for 2 new keys from Porsche at a cost of £380.
I was a bit mifffed to say the least. Anyway someone on here mentioned a company that can often help. Turns out they could, so £49.50 later I had a refurbished key with new front cover.
Basically my key died so I had no remote locking and not even the LED would light up on the key, even after I fitted a new battery. It would however still start the car, hence the transponder was fine so it wouldn't need replacing and reprogramming.
My circuit board was refurbished with new button, LED, battery and a new cover.
It works perfectly again. Good result and definitely worth bearing in mind if your key ever stops working.
Other than that the car has seen very light use on nice days. I will get stuck in soon, I'm just completing some outdoor housey stuff first.
The little Abarth has just clicked over 1000 miles so I'm going to do an oil and filter change as Fiat reckon it's ok to run the oil from delivery right up to the first service at 10k miles!
No way am I doing that, hence a change is due now as far as I'm concerned.
Anyway I have my Condensers, resistors and other parts, so the minute I can get onto the 996 I just need my rads and I can strip the front end.
Cheers.
C4pperS
PostPosted: Wed Jun 21, 2017 8:28 am    Post subject: Reply with quote
The Abarth looks great Mark Thumb
Sounds like a steal on the key programming as well, well sorted.
Marky911
PostPosted: Wed Jun 21, 2017 8:44 am    Post subject: Reply with quote
Cheers Cappers. Yes that key service is a great solution providing the programmed part of the key is still ok. Someone mentioned that company on a thread on here, so cheers to whoever that was.
More off topicness before I get some shut eye. Another car joined the fleet this week.
It's a red, Italian, 2 seater convertible. Nope not a Ferrari, although I wish. Wink
Alfa Romeo Spider for the grand sum of £300. What could possibly go wrong?
I've no tinkering time whatsoever so god knows why I bought it. I'm just a sucker for an old banger. MOT next week will decide its fate. Wink
Right, now to try and get some sleep in between these thunder storms and torrential rain.
Sleepy Happy
The Alfa's outside. It'll be interesting to see if the roof is water tight. Fisherman
Marky911
PostPosted: Thu Sep 07, 2017 4:08 pm    Post subject: Reply with quote
Righto, I can finally start getting stuck into the car now I think. A few months later than planned but anyway...
The car is off to my Indy at the start of next month so I have a few weeks to do the bits and bobs I want to get done first.
Pretty mundane stuff for now but the thread is about the running and upkeep of the car (as well as the adventures eventually) so I'll stick it in.
So anyway, before I start finding and sorting new issues/jobs I figure I'd better sort the things that I already know about.
First job was to clear out my bulkhead drains as reported by my Indy last year, after my brake servo issues.
An easy job, just clear the dirt out and pour some water through to check they're clear.
Well worth a check as it can lead to much bigger problems if it goes unnoticed, as it did with me.
No photos. Poor light.
I also ditched the screw in each of the side panels next to the battery cover. You remove these covers to access the bulkhead drains.
The screws always seize in the nut/rubber bung so the bung just spins rather than the screw coming out.
I fitted small caps in their place and use Velcro now instead of the bolts, as Porsche did on the 997.
Next it was onto the passenger door central locking module.
What started out as a one in ten times fault grew more persistent.
Basically the car sometimes wouldn't lock fully the first time I tried and also when unlocking I was getting the double beep from the horn.
My Indy plugged in his laptop last year and pinpointed the fault to the passenger door.
So last week I removed the door card, carefully peeled back the membrane (it's £50 if you rip it) and removed the module to identify it. There are a few different types.
I used these guides for door card and locking unit removal -
https://youtu.be/XgdImoLRv4k
https://youtu.be/yef6FHtDtcU
Once off I could see it was the 9 pin type so I ordered a used tested one for £40.
I also bought a bag of door card fasteners as the old ones were brittle. Plus the new ones have anti rattle foam washers.
I bought the clips from eBay -
https://www.ebay.co.uk/itm/381434051984
Old motor and the replacement, plus trim clips.
Ready to refit. Door membrane carefully pulled back.
Got it all fitted and it works perfectly with no more beeps when unlocking.
In other news that horrible old Alfa went. Failed it's mot miserably so ebayed it for £500.
My wife's Abarth has had its wheels done gunmetal as the black ones were doing my head in. Dirty looking within 10 miles after a wash. Rolling Eyes
Much nicer now.
Anyway apologies for an utterly mundane post. Better projects starting soon hopefully. Wink
996lee
PostPosted: Thu Sep 07, 2017 6:38 pm    Post subject: Reply with quote
I've currently started getting the same door locking problem
Which has now deteriorated into temperamental window not dropping when opened etc
So will be looking to do similar Thumb
Easy enough to DIY?
Edit ignore me just seen the video links Thumb
2001 Carrera 4 aero all the way!!
Marky911
PostPosted: Thu Sep 07, 2017 7:45 pm    Post subject: Reply with quote
Evening Lee,
yes all really easy as per the videos. The fiddliest part was detaching the small piece of rod that comes from the inside of the outer door handle and fits into a plastic sleeved knuckle joint on the motor. You can see the little sleeved arm in my pics of the motors. It's the small plastic arm at the front bottom right hand corner of each of those modules I photographed.
When removing you have to feel up to the outer door handle for that piece, slide the plastic sleeve piece down then flip the threaded bar out of the plastic arm.
Nothing hard, just fiddly.
Oh and the only other problem I had was the plastic screw in the door bin turned but wouldn't come out. I drilled the head off to get the door card off then ordered a new screw and female part. It actually just arrived today.
Apart from that it's a doddle. Probably 20-30mins removal and same for refit.
Good luck. Thumb
KP964
PostPosted: Thu Sep 07, 2017 10:15 pm    Post subject: Reply with quote
How you doin Marky , good thread nice motor Thumb ... i was chased down the A69 by one of those Abarth's the other day , wasn't you as i clocked the driver as i whizzed by Grin ... atb
Stone Grey Metallic 964 C4
Guards Red 964 C4 sold
Marky911
PostPosted: Fri Sep 08, 2017 5:40 am    Post subject: Reply with quote
Hi Keith, I hope you're well.
Nope I don't get to drive ours that much. I do the odd takeaway run to Morpeth or Ponteland as nobody delivers to Whalton but that's about it. Wink
I'm sure I've passed you once or twice when out and about though. Your car still looks ace. I will get out on some runs next year. Two main reasons I haven't this year are 1) Still busy on house. 2) I won't be happy with the car until I get it how I want, hence I've not really been that inclined to use it and coupled with no time, means it's just sat there this year. I haven't purposely not used it but at the same time I haven't made time to use it.
Next year will be better though. Anyway I'll see you around soon. Take it easy. Thumb
Marky911
PostPosted: Sat Sep 09, 2017 4:22 pm    Post subject: Reply with quote
Part of the work next month is a new water pump and low temp thermostat so I figured I'd fit a new auxiliary belt and check the pulleys before the car goes into the garage.
You need to whip your air-intake gubbins out to gain access and a clear view of the pulleys.
It's these three here. The right hand one is the tensioner. Use a 24mm spanner to take the tension off the belt and slip it off.
You can then rock them side to side to feel for play and spin them to check they're silent.
Mine were pretty good, but in the spirit of preventative maintenance I figured I'd sort them anyway.
New pulleys are anything from £60-£80 each whereas the bearings can be had for £19 each.
Bearings are available here -
http://www.bearingbasement.com/product/bearings/3202-bd-2hrs-tvh-fag-double-row-angular-contact-bearing-sealed/
I just thought I'd check eBay before ordering anyway. Sure enough a guy was selling 2 unused ones which I bought for £20 the pair, hence I only needed one more for £19.
Bearings pressed out -
I say pressed out but you can actually just knock them out with a mallet and drift. You're binning them anyway.
Back from powdercoating as bearings and belt arrived -
The centre bores are a precision fit obviously so they need masking then cleaning out before fitting new bearings.
Press new bearings in.
You do want a press for this although I dare say you could do it carefully in a vice.
Ready to go back on.
Back on. Don't forget the Loctite on the bolt threads.
After seeing the "Engine bay thread" the other day I felt shamed into cleaning mine. Very quickly though. I spent an hour on what is a days job really.
Stupidly I forgot the after pic.
I will need to sort the other pulleys in due course, oh and my engine in general as it's pretty grubby.
That's better. Stick all the air filter setup back in to hide stuff.
I have my bumper to engine bay strip back as I had it powder-coated with the pulleys but I'm waiting on a screw and speed clip. I'll refit it next week.
Anyway, mundane tasks but got to get through them.
Marky911
PostPosted: Mon Sep 11, 2017 7:47 am    Post subject: Reply with quote
Well, I'm down at Silverstone today driving the 991.2 GT3. I was here a year or so ago driving the Macan Turbo and Cayman GT4. This should be even better.
Damp but the sun is out so it might dry up.
Beats my usual Monday anyway. Cool
MMT
PostPosted: Mon Sep 11, 2017 8:49 pm    Post subject: Reply with quote
Did you fit the air intake.
I was wondering if you had the original air box and experienced the difference when it was fitted.
Mine had one on when I bought it and I bought an original air box and fitted. Personally I find mine so much better now.
Marky911
PostPosted: Tue Sep 12, 2017 6:49 am    Post subject: Reply with quote
Morning MMT,
K&N was on when car was purchased, but I was given the standard box too. I actually have another std box I was given too.
I haven't tried the standard one but I did try std vs K&N when I had my GT3 and to me the scream at the top end with the K&N on far outweighed any drawbacks.
Some people say they suck hot air but it's partitioned/sealed off and uses the original snorkel intake so it can't be too bad.
Again some say you actually lose 2 or 3 bhp but I've not noticed and the sound adds way more to the experience than a few bhp would.
I appreciate its all subjective though, just like whether you prefer red or blue. I may well have a bit of experimenting between standard when I get through everything else though, as there seems to be as many people who don't prefer aftermarket filters, as do. Thumb
Gixxer996
PostPosted: Tue Sep 12, 2017 7:41 am    Post subject: Reply with quote
Mark,
Im really enjoying this thread. I like all the detail of powder coating bits and bobs which most people wouldn't do - Im the same and think these are the bits that make the difference between a nice car and an enthusiasts car.
Great work - keep it up! Its going to be a lovely motor when you are finished. Thumb
Guywilko
PostPosted: Tue Sep 12, 2017 1:01 pm    Post subject: Reply with quote
Nice work
Are all 3 bearings on the pulleys the same size? 15mm x35mm x35.9mm??
Cheers Guy
996lee
PostPosted: Tue Sep 12, 2017 2:28 pm    Post subject: Reply with quote
how was the 991.2 gt3 then? Cool
Marky911
PostPosted: Wed Sep 13, 2017 4:50 am    Post subject: Reply with quote
Hi Gixer, cheers and yep it's the little things that count. Do it right, do it once.
Hopefully by next summer the car will look like a black version of yours. Thumb
Cheers Guy and yes all 3 pulleys use identical bearings as in the link above.
I actually had an email off them the other day for 10% off people's first orders. I'll pop it on here later for anyone who may want to buy the bearings. It'll only knock a fiver off but it's better in your pocket than theirs. Wink
Mornin' Lee - That GT3 is rubbish. Can you believe it doesn't even have a cable throttle? I didn't even want to drive it when I found that out. I had a go anyway but the wiggly stick was missing from in between the seats and I had to pull on these flappy things attached to the steering wheel. When you pull on them they alter the sound of the engine and the position of the needle on one of the gauges. All a bit weird. Wink
Seriously though it's awesome, as you'd expect. 9000rpm screamer. The track dried out nicely so we could push on. Engine awesome, brakes awesome, everything awesome.
Big thanks to my mate Paul for using up his +1 on a freeloader like me. Very Happy
Paul has owned every generation of GT3 now including my old 996 before me, then a 997, 991.1, and now a 991.2. Not to mention a GT4 too, which again I got to go and drive at Silverstone.
His .2 will be manual though and whilst we both agreed PDK is good around the Porsche centre, as you have enough to do anyway, on the road they leave you a little cold.
Some lovely cars there including the 911R outside and a 997 Sport Classic.
Fantastic fun and a great setup they have there. Nice food too.
Well worth the 5 hour drive from oop north. 4 of us went down as our mates Mark and Mark were using up Marks 991GTS day. Travelled down on Sunday afternoon to the hotel. Meal, beers, bed then Silverstone on Monday morning.
I can recommend our instructor. Paul always asks for him when booking. Ed Pead. Great lad. Races bikes but has also done lots of car stuff.
For my last 5 minutes I asked him to drive and me to passenger.
Wow! Sideways around an entire lap after a flying lap properly before that.
You think you're quite a quick driver until you go out with a racer.
Superb!
Anyway you get the gist. Anyone reading, if you ever get the chance to go PEC Silverstone, jump at it. It's the most fun you can have with your clothes on. Thumb
Yas.SYC4S
PostPosted: Fri Sep 15, 2017 10:51 am    Post subject: Reply with quote
Great work mark! Really interesting thread.
Tad jealous you got to drive a 991.2 GT3 around Silverstone! I need to book myself a Porsche experience day Smile
I changed my Aux belt the other day. I did notice little play in one of the roller bearings. I have been getting a squeak on idle (not all the time). So i think i will order those bearings and refurb my rollers. Simple and cheap fix option.
How long did they take to arrive? I wouldn't mind the promo code if you have it please.
Speed Yellow - 996 C4S (EVO Magazine)
Laguna Seca Blue - BMW M3 E46 (2003)
Guards Red - Porsche 924 (1982)
Lachs Sliver - BMW E30 Mtech 1 (1987)
Alfa Red - Alfa Romeo 1750 GTV Mk1 (1969)
Marky911
PostPosted: Fri Sep 15, 2017 11:56 am    Post subject: Reply with quote
Thanks Yas,
Squeal at idle could be a few things. If you span everything while you had the belt off and only the pulley has play, then yes you may aswell start there.
Obviously alternater pulleys can squeak and I've even seen an aircon clutch fail, so even though the aircon is off it puts the belt under massive load.
Spraying a bit of GT85 on things while it's squeaking often pinpoints it too, as the squeak will go silent for a little while.
Anyway 10% discount code below. Let me know if it isn't right.
https://www.bearingbasement.com/?redeem=59aded5cdacbf00050f9425e
The bearing was probably the fastest thing I've ever had delivered.
According to their website they're in Ireland, yet I ordered at 6.30pm one night and it arrived at 9.30am the next day. I'm guessing they have distributors elsewhere.
Great service either way.
Good luck if you go ahead and swap the bearings. Very simple. Thumb
PS Unfortunately you don't actually go around Silverstone on the standard PEC day. They have their own track with extras such as kick plate and low friction surfaces.
You still get up to flat out in 3rd which is ok in GT3/4.
I believe you can save your vouchers, so if you bought 4 cars you can use all 4 tokens to drive a one around Silverstone. The standard PEC day has a value of £500 you see yet the Full Silverstone one is £2k.
I think that's correct anyway as my mate Paul was going to do that but there's a massive waiting list for the full one.
Even the Porsche track is great fun though. The kick plate and low friction surfaces teach you a bit about car control, if you aren't experienced in that already. We have all done karting and trackdays etc and you pick a lot doing that anyway.
EDITED TO ADD -
If link doesn't work try this as code.
P60Q-VLNH-AA5G
Yas.SYC4S
PostPosted: Fri Sep 15, 2017 12:50 pm    Post subject: Reply with quote
Thanks mark, much appreciated.
Its strange, I get the sequel once warm, stationary with air con off. Slight rev and the sound goes, sometimes it returns sometimes not. I can hear a noise coming from the pulley area, so just need to identify which one.
The alternator is new, so doubt that. When I had the belt off and span the pulleys, I noticed more play in the top idler pulley (not much) just noticeable. All the rest seemed okay, water pump looked good (will be changing this in my major service along with an LTT and new coolant).
I think I will change the bearing on the top idler pulley, and report back. Hopefully I can say bye to the squeak.
Thanks again, great tip on replacing the bearing rather then shedding out more money unnecessarily. thumbsup
I will look into the Porsche Experience day (birthday is fast approaching), to drive the 911/gt3/gt4 around a track will be a blast. Great day out plus not wearing down your own rubber! Grin
Marky911
PostPosted: Fri Sep 15, 2017 3:03 pm    Post subject: Reply with quote
Good luck. I hope it cures it. Failing that or even before, try the gt85. Only a fiver a tin. May pin point it.
Can't hurt to renew that bearing anyway though.
Yep that's the best thing about PEC. It's using their tyres.
This is how we brought the Macan Turbo back. Grin
Goto page Previous  1, 2, 3, 4, 5 ... 29, 30, 31  Next
Page 4 of 31
