Hi All,
This is my first ever post about my first ever 2005 911 997.1 C4S.
(Actually just re-posting this from the Newbie forum)
Have owned the car for about 18 months now with no issues.
Recently have experienced random misfires in multiple cylinders.
Diagnostic readings have been P0300, P0301, P0303.
All 6 coils have been replaced and now considering changing the MAF.
Spent time today trying to establish what sets off the misfire as well as what cures it albeit temporarily.
Things that set off the misfire
When starting from cold the car runs fine and idles around 1,200 rpm
When the choke cuts out then the engine idles below 800 rpm and begins to misfire
Switching the engine off then on again settles the idle and cures the misfire
When the engine is warm and running smoothly, if the throttle is blipped VERY gently then the engine continues to run smoothly.
If the throttle is blipped normally (not gently) up to say 3,000 rpm and allowed to drop to idle then the car runs below normal idle and goes into misfire again.
Switching the engine off and on allows the car to idle normally once again.
Wondering if anyone else has experienced these symptons and whether they found a solution to this.
Thanks and sorry for the long first post!
