Hi guys,
I had an engine rebuild on my 2002 996 3.6 C2 not too long ago (just over 2 years ago), and cause or not, when I got it back it had a new battery installed as well (rubbish one, now replaced), and some fuses had blown, causing the radio not to work. I figured it may have been jump started or fast charged with resultant spikes causing the fuses to blow.
So when it came back, I had an assortment of errors that are still ongoing, yet intermittent. I replaced the audio fuses when I got it back and all was ok. Recently the screen of the PCM gave way, not sure if related or not, over 2 years later - probably not, but just including as a matter of course.
The errors that have been difficult to track have been listed below.
When driving, and when came back from rebuild over 2 years ago until current:
- Intermittent oil pressure sensor failure warning, gauge looks fine otherwise when working
- Intermittent water temp sensor failure warning - needle takes a long time to climb to operating temp also. I was thinking that the stat may have been stuck open, but don't think so. I presume it's the sensor or an electrical fault, due to the other faults present.
Can't remember if both sensors were replaced, but I think the water temp sensor was.
Recently (last couple of months):
- Despite recent new battery and alternator check, alternator light comes on periodically.
I just wonder, having replaced (some or one) of the sensors, what else could it be? Are these issues related? On the same circuit?
Maybe it's not the sensors themselves because replacing one didn't work, and it's intermittent.
Something to do with getting it back from this garage? Spikes?
Refurbishing the car and want to get all the little niggles sorted, having owned the car for over 8 years.
I personally think something has been damaged, as the electrical faults seem more blanket, than specific, especially given the surrounding picture.
What are your thoughts guys?
Luke.
Luke.
