leeshephard
- Joined
- 11 Jan 2009
- Messages
- 85
Hi
The AC on my car has never worked, and as I have a European trip booked next year I decided this was the year to get it working. I have replaced the Condenser, Evaporator, Expansion valve and dryer. I drained the old oil from the compressor and refilled with new PAG Oil.After flushing all the pipes and reassembling , I then pressured tested to 40 PSI and then deep vacuum for 3-4 hours and left it overnight. I then refilled by weight with 840g of R134a.
Ac now blows nice cold air! Well, sometimes....
Fault Description:
- Start car from cold engine (left overnight). AC Condenser fan runs, Compressor runs. Cold air at vents. ( I left the car running for over 30 mins and AC continued to work correctly)
- Stop car leave for a few mins (waited for CCU internal fan to stop) then started car. NO AC CONDENSER FAN AND NO COMPRESSOR RUNNING. CCU looks fine, all buttons lit up as normal but no cold air.
- Stop car and connect to CCU using scantool - no fault codes found.
- Repeated starts of the car with 20-30 mins yield same issue.
- If car left for a few hours AC will work as normal.
Starting settings:
- Car in garage on axle stands.
- Ambient temps around 18C
- CCU Fan speed on 4, Temp on blue dot, AC Max button On, Resirc Button On, both sliders left most.
Previous diagnostic checks performed:
- AC gas pressure checked with proper dual manifold gauges and is within spec in factory manual.
- Using the Rennlist/ToreB scantool connected to CCU and ran the test program. All fans and servos activate and run correctly.
- No fault codes stored in CCU
I am a bit stuck now! It seems to me to be an issue with the CCU, a dodgy transistor maybe?
Any help is gratefully received.
Lee
Fault Description:
Starting settings:
Lee
