queenmonkey
- Joined
- 13 Jul 2016
- Messages
- 78
Hi guys some of you might recall that i'd previously posted that my recently acquired ('98) 996 had needed constantly topping up with coolant (about a litre a fortnight). The guy i'd brought it from said it'd had a new rad fitted in the last month and i need to keep an eye on it. Well i've brought a new OE cap for it (suggestion on the other thread), no signs of a leak and expansion tank is quite new. I continue to top up and usually more after a longer (10 mile) run. I only tend to use it for short (4 mile) journeys.
Well thought i'd take it to my local indie. He thought it might be the pump but on inspection said it appeared fine. He took it for a drive and was impressed with how it pulled. He couldn't find a leak although commented on a very slight misfire (on tick-over) on cylinder 1. I didn't take much notice of that because for an 18 year old car i wouldn't expect a perfect tickover. He's suggesting that as (my) worse case scenario it might be the start of a blowing head gasket? Suggestion is to keep on topping up and monitor the misfire to see if it gets worse? They checked the coil pack on no1 and say it was ok.
I'm feeling a bit bemused now thinking that they might have been able to diagnose it. Not sure where to go now other than to keep topping up!!
