991 : 2011- 20
997 : 2004- 78
Boxster : 1997- 25
Vikski
PostPosted: Sun Sep 25, 2016 10:03 pm    Post subject: 911 1971 Engine Relay Board wiring - Help! Reply with quote
Hi, I have bought myself a lovely 1971 911T Targa. most of the car is in pretty good condition however the engine bay looks like an electrician worked on it whilst blindfolded using an axe. Surprising the engine works fine, just the wires are very untidy. See pic attached.
In an effort to tidy up the wiring I am looking to install a new Engine relay board plus all the relevant wires / harnesses to get it back to what it should look like and work properly too.
I have found a new mounting plate from Design911 but I wanted to know where to get replacement wires that connect the fuses, resisters etc on the board. Mine are clearly non-existent..also are there any simple pics that show how to wire this baby properly back to how it should be. Wiring diagrams won't help..
Also, as you can see I don't have an original spark box. Where can I get one from? Or do you advise me to get a modern version like the classic retrofit version.
Thanks in advance![/img]
 Filesize:  449.82 KB
 Viewed:  6730 Time(s)
Palladium
PostPosted: Mon Sep 26, 2016 7:03 am    Post subject: Reply with quote
give autofarm a ring, nothing they don't know about any aircooled era, they are near m40 at Bicester, they have specialists for every type of issue.
hot66
PostPosted: Mon Sep 26, 2016 9:05 am    Post subject: Reply with quote
get yourself on to the DDK forum . you'll find all the help you need .. Autofarm ? .. prepare to have an empty wallet Floor
James
1973 2.4S
1993 964 C2
gone :
1967 2.0 SWB 911
1995 993 C4 Cabrio
2003 996 Turbo DMS
2003 M3 CSL
DDK
PostPosted: Mon Sep 26, 2016 6:49 pm    Post subject: Reply with quote
Ive done a few tidy ups of that area .. its not that hard , you can always replace each wire in turn if unsure .. i would start by opening up that harness and seeing what lurks inside Smile
Anyways .. wireing diagram ive found usufull , look for no.3 and the fusebox next to it ..
http://www.pelicanparts.com/911/911_parts/Electrical/911_electrical_1965_911S.jpg
Ignition system upgrade and ive fitted these and also seen a few .. seems popular ..
https://www.msdperformance.com/products/ignitions/
You want the daily driver range .
It should look something like this ..
https://static1.squarespace.com/static/561f82cae4b0ffccfc049e66/563ce6e2e4b048c548558e6a/563ce92ce4b07255a4649851/1449668721832/page15-1003-full.jpg?format=500w
Palladium
PostPosted: Mon Sep 26, 2016 7:27 pm    Post subject: Reply with quote
yeh, they do charge, mine is there now, but they do it properly, with full guarantee, I used another specialist recently to try someone different, they charged even more and got on my tits.
Vikski
PostPosted: Mon Sep 26, 2016 10:23 pm    Post subject: Thanks Reply with quote
Thanks for your advice all!
Does Porsche supply all these parts still fo the relay board - or is there a spares website for these items?
Porsche 997C2S
Porsche 911T Targa 1971
hot66
PostPosted: Tue Sep 27, 2016 8:23 am    Post subject: Reply with quote
you can download PET from Porsche which has all teh porsche diagrams.
Parts wise, if you want good used put up a wanted add on ddk www.ddk-online.com
James
1973 2.4S
1993 964 C2
gone :
1967 2.0 SWB 911
1995 993 C4 Cabrio
2003 996 Turbo DMS
2003 M3 CSL
DDK
