Ponyboy Curtis
- Joined
- 30 Nov 2015
- Messages
- 43
Evening all
Lovely chap at Brooklands had to look round my C4S and popped it on the ramp and came up with the below list of repairs.
Would you do them? If so who with and at what sort of money?
Look forward to your opinions as always.
1 Renew the rear brake discs and pads, with the fittings, sensor and protective back plates
parts
Rear brake discs x 2
Rear brake pads x 1 set
Disc screws x 4
Protective back plate due to rusted away x 2
Calliper bolts x 4
Pad damping plates x 8
Warning contacts x 2
parts total £667.00
Labour total £145.00
Subtotal £812.00 + vat £974.00 inc vat
2 Renew rear brake calliper lining plates if found to be required when the rear brakes are apart due to alloy corrosion and distorting the calliper plates
parts
Calliper plate kits upper and lower if required x 4
parts total £107.00
labour with brake apart £170.00
subtotal £277.00 + vat £332.40 but may not be required, cannot see them until brakes stripped.
3 Front suspension bump stops perished and falling apart, Renew the bumps stops and the gaiters
parts
Top shock absorber nut x 2
Bump stops x 2
Gaiters x 2
Parts total £50.00
Labour total £255.00
subtotal £305.00 + vat £366.00 inc vat
4 Lower front lips spoiler renew
Parts £65.00
Labour£30.00
subtotal £95.00 + vat £114.00 inc vat
5 Boot floor drains renew £26.00 inc vat
6 Head light vents below front boot floor £18.00 inc vat
7 Battery earth lead for the later super seeded part
Part £21.00
Labour £35.00
subtotal £56.00 + vat £67.20 inc vat
8 Rear left outer drive shaft boot split, remove rear left hub to remove the left drive shaft and renew the inner and outer drive shaft boots and fittings
Parts
Drive shaft boot x 2
drive shaft cap
Circlip
gaiter clip x 4
C/v greas
Drive shaft nut
drive shaft bolts x 6
parts total £125.00
subtotal £380.00 + vat £456.00 inc vat
9 Timing chest base cases leaking engine oil, remove the engine and place on the engine stand, strip down and renew timing chest gasket and seals, remove and refit timing chains, reset the valve timing and rebuild refit to the car and fill with oil and road test
parts
Gaskets, seals and fluids. £846.00
Labour £2125.00
subtotal £2971.00 + vat £3565.20 inc vat
:thumb:
parts
Disc screws x 4
Calliper bolts x 4
parts total £667.00
parts
parts total £107.00
parts
Bump stops x 2
Gaiters x 2
Parts total £50.00
Parts £65.00
Labour£30.00
Part £21.00
Labour £35.00
Parts
drive shaft cap
Circlip
gaiter clip x 4
C/v greas
Drive shaft nut
parts total £125.00
parts
Labour £2125.00
:thumb:
