Hi all,
I have been a little quiet here recently due to work and other things going on.
Last Thursday I dropped my car off with Jaz Porsche St.Albans to have my H&R 20mm lowering springs fitted along with a fast road geometry set up and to also have a fresh set of Michelin Pilot Super Sports fitted. Some of you may ask why I decided to do this to a car of this calibre, some will be keen to see the pics of the before and after and some will want to know if there was any improvement..
Why did I do it?
Ok first up I have to admit, I really didn't like the way the car handled stock. I was on the basic Pirelli P Zero tyre courtesy of Porsche which I know was half my battle. My car would understeer followed by a huge oversteer. Sadly my A45 was A LOT better. I found the car to be a little un settled mind corner too, I could never build any confidence. I looked into lowering after being in 2 friends 997.2 Turbo's and Turbo S who where on the H&R. I chose the MPSS as I have used them on my previous cars. I saw a huge .5 of a second gain on my 0-60 with my A45. Stock with its Dunlops was 4.5, stock with the MPSS was 4.0. Lets see if history was to repeat itself.
First Impressions?
Wow... the car is so much softer than the stock springs. Even with the PASM activated, it's so much better than before - even on a terrible Hertfordshire road. Road noise.. wheres it gone? The MPSS are so quiet! I have kept stock sizes to ensure correct fitment along with not upsetting the AWD system. Turn in is lovely and direct, feedback through the steering wheel is in real time, the level of grip is incredible... It's what it should have been from the factory!
I decided to do a launch on a private test track on the Autobahn in Mexico on Mars.. as you do.. ha! I do not run my VBOX with role out on. I run a true 0-60 - not 4-60! My previous best times at Terminal Velocity in 26 degree heat where 3.3 to 60. I ran the car again with the MPSS in a 16 degree heat to see something quite amazing...
I have managed to break into the 2's stock! This is purely down to grip and having more contact with road on launch. Stock cars lift like crazy you will see in a previous post I did at Santa Pod. Now this has gone and the 235's stay on the ground to help the big 305 brothers out.
We are now at 2.9 0-60 - again no role out.
A big thanks to Jaz Porsche for a great job. I dropped the car off Thursday, they had it all done ready for the evening. They advised me they wanted it to settle over night before doing the fast road set up. I was worried my top mounts would need replacing as this seems really common but luckily mines ok. The next day I had a call mid morning to say it was done and the rest is history.
If you are thinking about doing this to your car then I hope I have helped answer any questions you may have had.
- Steve
PS: more toys arriving next week
Why did I do it?
First Impressions?
- Steve
