Having read through various threads on engine temp etc I've been monitoring my own.
In town I've been steadily over 100 so thought I would start by cleaning rads as there was a lot of leaves built up in there, the engine fans appear to come on around 105 and cool back to approx 100.
Coolant level was also on the minimum so this still requires topping up.
The fan on the boot lid is not working, I removed air temp sensor from the manifold but still no engine fan, I checked the fuse which was fine then went for the relay this is where I got confused.
The relay 4 numbers, 30,85,86 & 87
No. 30 is live via the fuse and 87 is switched live to power the fan,no. 85 should earth to ground and 86 I assume should be the trigger that energises the coil. Problem being, I have 12v down both 85 & 86 and this is why I think the fan in boot lid is not firing up.
I bridged power at the relay and the fan worked.
I checked resistance on the sensor and that's good too
Has anyone got any knowledge on this at all, I presume the engine fan not coming to life will not be helping my temps
