997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Piers993
PostPosted: Sun Jul 24, 2016 1:54 pm    Post subject: Brake light bulbs blowing almost instantly Reply with quote
Hi, my 1997 993 recently started blowing brake light filaments. When the brake light bulb goes, I can tell because when I brake, the front side light lights up and I can see this reflected in the car in front. Only the same side as the blown brake light bulb lights up.
When I replace the bulb, it works fine for a short while but blows again within hours.
Any ideas?
964hans
PostPosted: Sat Nov 25, 2017 4:14 pm    Post subject: Reply with quote
Hello Piers,
Please measure your battery voltage and generator voltage.
Should be between 13 and 14 Volts while engine is running
PostPosted: Sat Nov 25, 2017 9:51 pm    Post subject: Reply with quote
Also have a good look at the bulb connections as they may be shorting out .
Check the light unit earth as well .
Indy Mechanic .
