Hi
Grateful for any advice on windscreen seals. The windscreen seal has started to come away from the body at the top. I only noticed as I was starting to get some significant wind noise at motorway speed and it is pretty difficult to spot just by looking at the seal.
Specialist has tried to fix with with some sealant / bonding agent but this has actually made it worse as it didn't stick (not quite sure what was used). The advice is now to go down the route of a new windscreen to get the seal right - not even refitting the current windscreen! This sounds a bit extreme and is definitely extremely expensive.
Any thoughts or guidance gratefully received.
J
J
