997 : 2004- 89
996 : 1997-2005 41
993 : 1993-1998 6
Boxster : 1997- 15
Cayman : 2005- 11
Macan : 2014- 0
Kcredfan
PostPosted: Fri Jul 15, 2016 7:36 pm    Post subject: Lowering 997 Reply with quote
I would like to lower my 997.1 3.8s can anyone offer any advice, I am only doing this from a visual thing.
I want a similar stance to a GT3 not dragging on the floor !
What brands are best suited for road use ?
Thanks in advance Thumb
997 3.8 carrera s owner
basildon993
PostPosted: Fri Jul 15, 2016 9:14 pm    Post subject: Reply with quote
I'm having my Turbo lowered next week! Have gone for H&R -20mm springs which seem to be a popular choice. Will take before and after pics and post on here. I have also gone for a fast road geo at the same time. Once the car is lowered I will then consider if spacers are needed.
997.1 Turbo Coupe Manual
ex 993 Carrera 2 Manual
ex 3.2 G50 Carrera Targa Manual
ex Chevrolet Camaro IROC Z Manual
crlincoln
PostPosted: Fri Jul 15, 2016 9:58 pm    Post subject: Reply with quote
I lowered 997.2 C2S on H&S -20mm springs, when I had suspension tweaked by Centre Gravity they did a full set of ride height measurements and said it was now identical ride height to 997.2 GT3.
997.2 C2S PDK + cargraphic silencers + H&S Bypass + H&R Springs
PostPosted: Fri Jul 15, 2016 10:18 pm    Post subject: Reply with quote
I lowered mine with techart springs 20mm, very pleased as it doesn't sit right up in the arch but just gets rid of the arch gap. they are made by eibach but to a different spec and only drop 20mm whereas some brands drop 25/30mm and I have had them 2years and the car has not continued to drop as happens with some brands. , you will need a geo done and look at spacers to complete the visual . if you have a standard front bumper you will only very rarely scrap, if you have an aerokit or anything with a lip you will scrape often and the lip will become an annual change job £180 but worth it to get the look right. Thumb Grin
antonio
2005 Porsche 997 Carrera 2S
PostPosted: Sat Jul 16, 2016 7:07 am    Post subject: Reply with quote
Im thinking of lowering mine, anyone know how many hours labour this would take ?
marconorth
PostPosted: Sat Jul 16, 2016 8:38 am    Post subject: Reply with quote
Good point about some springs continuing to drop as the years pass. Nobody has mentioned anything about about the H+R's doing this so presumably they maintain their height after settling too.
2008 997.1 Turbo Man.Black/Black- Pampered!!!
crlincoln
PostPosted: Sat Jul 16, 2016 9:19 am    Post subject: Reply with quote
I had brookspeed do my in Eastleigh, Hampshire and all in cost I think was about £580, springs and labour...
antonio
PostPosted: Sat Jul 16, 2016 1:55 pm    Post subject: Reply with quote
Thanks, that doesnt sound too bad.
PostPosted: Sat Jul 16, 2016 2:37 pm    Post subject: Reply with quote
Brookspeed did mine also I supplied the techart springs they fitted them, they know there stuff and won't rip you off. Thumb
M9JOC
PostPosted: Sat Jul 16, 2016 2:58 pm    Post subject: Reply with quote
Same. I lowered mine on H&R -20mm. been on 10k miles. Looks good, drives well no issues at all. Springs still look like new, no wear.
2007 (57) Porsche 997 Turbo (Tip) in Slate Grey
20" HRE Alloys on Continental tyres, 9E Stage 2 inc IPD,TB & chrome Y-Pipe, Europipe+100CEL, -20mm H&R springs. Gen 2 front & Rear bumpers, Chrono, Adaptive Sports Seats, Full Porsche Aerokit
DeathStar
2006 Porsche 997 Turbo
PostPosted: Sat Jul 16, 2016 4:09 pm    Post subject: Reply with quote
Same here; H&R -20mm springs, plus 15mm spacers front and 20mm spacers rear. Thumb
“The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence.” ― Charles Bukowski
basildon993
PostPosted: Sat Jul 16, 2016 5:00 pm    Post subject: Reply with quote
Mmm, I was thinking of going for the 'standard' 7mm front / 15 mm rear? Will have to see what the car looks like when I get it back from lowering.
DeathStar
PostPosted: Sat Jul 16, 2016 5:19 pm    Post subject: Reply with quote
I had 7mm F and 15mm R at first - but as others have said on here; the 7mm spacers just don't bring the wheel out enough (I'm on standard 997.1 turbo wheels), plus they're not hubcentric - so I took the 15mm's off the rear and put them on the front, then put some 20mm's on the rear - looks spot on now Thumb
basildon993
PostPosted: Sat Jul 16, 2016 5:47 pm    Post subject: Reply with quote
I'm running standard wheels to. Decisions, decisions. Very Happy
Kcredfan
PostPosted: Mon Jul 18, 2016 7:32 pm    Post subject: Lowering Reply with quote
Thanks guys for all the advice, as soon as my car is back from the dreaded bore score hospital I will be onto springs, spacers and geo.
Regards
basildon993
PostPosted: Mon Jul 18, 2016 7:39 pm    Post subject: Reply with quote
My car is in today for lowering and fast road geo. Can't wait to see it! thumbsup
PostPosted: Mon Jul 18, 2016 9:21 pm    Post subject: Reply with quote
pics asap please Thumb Grin
RichardKS
PostPosted: Tue Jul 19, 2016 9:33 am    Post subject: Reply with quote
Consider also Eibach Pro Kit springs. I have them on my 997 Carrera S. Lower than standard, but not exactly grass-cutter low. Reduced body-roll upon turn-in is a major improvement.
antonio
PostPosted: Tue Jul 19, 2016 8:17 pm    Post subject: Reply with quote
I am watching a listing on ebay for these, seller is from Germany and they are a bit cheaper.
Boba fett
Watkins Glen
PostPosted: Tue Jul 19, 2016 8:47 pm    Post subject: Reply with quote
I'm lowered and Spaced with what is now Eibachs. I had H&R's put on the car first and with the aerokit it was just to low and I scraped on every speed hump.
The Eibachs are just a nats c@ck ( just under 5mm higher) and it made a difference !!
Goto page 1, 2, 3, 4  Next
Page 1 of 4
