ColinC
- Joined
- 16 May 2013
- Messages
- 1,030
Renewed the bearing and glued the casing back together with an epoxy based glue about 3 years ago - just spilt causing the gears to grind on lowering the spoiler - to much movement.
Has anyone used a glue that works or is there another solution apart from the obvious - £250 for a new one!
