I've found leaky rear footwells so followed the posts on here and the US site and taken the rear wheel arch out and cleaned the gromet.
It's still leaking in from a grey disk under the carpet at the bottom of the seat (where your ankles would be if you were sitting there). Does anyone know what this grey disk is please?
I'm wondering if I need to gently rod the drain hole (under the wheel arch) or whether the drain tubes behind the speaker etc, have holes in them.
Thank
You
Can't seem to add images from the iPhone
Thank
You
