Hi, I have a 997.1 turbo on a 56 plate. During its mot it was noted that the under tray had fluid on it. It was traced back to the clutch reservoir in the front appearing to overflow. I have done a bit of research as this would point to the clutch slave potentially on its way out?
However, I have no symptoms of any other issues. No cold start problems with pedal, accumulator seems fine as pedal only goes really hard after 25 pumps, then after idling for 20seconds and engine off pedal again is fine for another 25 pumps.
All gears engage with no issues, apart from usual stiffness into 2nd as short shift fitted.
I have no idea how long this has been going on for, but car was serviced last year and it wasn't there then, frankly I wouldn't have known about it now if I hadn't been looking underneath when it was on the ramp!
Will I be doing any other damage if I leave it till I experience the usual problems with failing slave? Or will this result in damage to other areas (by the way fluid level when cold is exactly on max in reservoir)?
Thanks in advance.
Thanks in advance.
