997 : 2004- 63
996 : 1997-2005 29
Boxster : 1997- 26
PostPosted: Sun Mar 20, 2016 7:57 pm    Post subject: Diagnostic Help - No Electrics (at All) Reply with quote
Chums
Looking for some advice/confirmation on this one. Took the Silver Surfer out today Rolling Eyes and all going well. Actually 'sort of' as there is a hesitation issue on constant throttle at steady constant speeds but I'll come to the 'big one' first.
Parked it up after a leisurely drive alarmed etc and then came to get back in. Car started fine but I 'think' I heard something like a spark/fuse blowing/electric arc behind the lower dash towards passenger side. Wasn't sure so decided to turn off and restart.
I turned the ignition off and then went to crank up - nothing Surprised No power at all to anything electrical, even the alarm not functioning. So whilst I was sat there deciding at which point I called recovery to look a right knob in Alderley Edge village I had a fiddle about under the dash just checking connections etc before going on to fuses.
After about 5mins I reinserted the key with a bit of poking it around the barrel all the lights came on and good to go.
Once I got home I tried to replicate the incident and again I ended up with no electrics but not sure what I actually did. After a few mins put the key in and tried again and all normal. On both occasions the clock had stopped for the times I had no power.
So I'm thinking
1) its an earth/battery connection issue - checked that and looked all fine
2) its a clock issue given that power is routed through the clock and might need the connections cleaning?
3) its an ignition key plug (behind the barrel) issue - but not sure this would isolate all electrical power including those that still work with ignitioni off?
Any clues? The more I think about the noise I'm thinking it's in my head, not connected or the 25 bags in change in the glove box in case I find a 993 for sale Grin
Issue 2:
In relation to the 'rough' running. Engine seems 'hesitant' at a constant speed - hunting/surging very slightly. Tick-over is no different to usual (964 lumpy as its always been) and acceleration in all gears/range is perfect. It's only at a constant speed I can feel something. I've just gone over to super unleaded in case it was crap supermarket fuel from last time.
I was thinking fuel filter but would expect issues at idle/acceleration? Major service is due so filter/plugs etc will be changed.
The game's afoot. It's time to put a bit of (Colini) stick about......"Shall I open her up Miss Jones and show 'em a clean pair of heels?" "Do you think that's wise Mr Rigsby this is a very old car"
grbspeedster
PostPosted: Sun Mar 20, 2016 8:20 pm    Post subject: Reply with quote
Not sure as all electrics go but, have you looked at the bulkhead plugs. On my old SC I recall a similar incident after fueling up turned out the plugs behind carpet on bulkhead had come apart. On mine think it had three round plugs that went through bulkhead near the where the steering shaft went through bulkhead. Might not be same on 964 but worth a look. Think the connections worked loose as carpet moved
Good luck it's frustrating when you get these issues
Geoff
996 X50 turbo cab
PostPosted: Sun Mar 20, 2016 8:22 pm    Post subject: Reply with quote
Geoff - Thanks but I dont think 964 have the issue you refer to Dont know
Chief
PostPosted: Sun Mar 20, 2016 8:26 pm    Post subject: Reply with quote
Zingers, my old chum, I would go with the ignition switch behind the key barrel. This would be my number one suspect at it controls everything. My dad had the same problem as you describe with his many years ago and no one could track it down. It was only when I had a multimeter on the fuel pump and observed it as he started the car up, that I could see the power going on and off with waggling the key in the ignition. It would effect partial load only and occasionally no power at all. just to test, I'd start the car and hold the revs up a bit as you waggle the key to see it replicates the symptoms. Just think how many times that ignition switch has be used in the life of our cars!
All the best,
Chief
P.S, I'd change out the fuel filter whilst your at it. These seem to be left untouched for years! Cheap and easy to change....
ras62
PostPosted: Sun Mar 20, 2016 10:14 pm    Post subject: Reply with quote
Another vote for ignition switch.
For the rough running, see how she runs on only one distributor at a time. Is the O2 sensor old? Is the air flow meter flap operation smooth?
PostPosted: Sun Mar 20, 2016 10:30 pm    Post subject: Reply with quote
Ignition switch on the barrel is the only moving part in all this (apart from the starter turning) so my gut feel would be the barrel. Also, do you have an immobiliser? I've always had ignition problems (and electrics) with immobilisers, especially retro fitted ones.
Even my ET4 scooter only stars 50% of the time. Take key out, replace, turn over, and bingo - starts.
PostPosted: Sun Mar 20, 2016 10:40 pm    Post subject: Reply with quote
Thanks chaps I'm hankering on it being the ignition barrel. One for picking up during the service or next weekend when I get chance.
Looking at This DIY from Pelican means I can do the back without affecting key changes etc
PostPosted: Mon Mar 21, 2016 5:16 pm    Post subject: Reply with quote
OK chums whilst I was hoovering my belly button in anticpation of ordering the parts I've had a thought Question
Would the ingition switch failure cause a total loss of electrical power? I'm thinking here that the clock is on a cirucit completely independent of the ignition (as is the alarm) so would it deprive all these of power as well Dont know
Jcx
Estoril
2010 Porsche 997 Turbo
PostPosted: Mon Mar 21, 2016 5:37 pm    Post subject: Reply with quote
upstairs for thinking Mister Z! thumbsup
PostPosted: Mon Mar 21, 2016 6:47 pm    Post subject: Reply with quote
You had the car running , thought something was wrong so turned off the car and it had no electrics at that point .. so ... that means the generator was running the electrics up untill you turned it off .. there was no battery connection.
You left it a while and it restarted , my thinking is something got hot maybe the noise you herd and when cooled down restarted.
Ignition switch ?? i dont think so , at least looking at the diagram i dont , fine if it wouldn,t start etc but no electrics at all ?? no interior light , no clock etc .. not controled by the ignition switch i think , i did a bit of digging and found a partial wiring diagram , cant say if its exact for your year but its a guide.
Theres a couple of connection points that might be the fault but my gut feeling is the battery leads .. do you have a green top battery isolator on your car ? if so remove it , can you use a jump lead on the earth side to give it another earth and reproduce the fault ?
http://www.porscherepair.us/porsche-964-911-carrera4-5/images/2136_17_110-pin-dme-porsche-944.jpg
On the battery it shows 6 leads comeing from the positive side .. do you have six or just a couple that run to a connection point ?
Battery is at K 50 btw
Kind of job i love to get stuck into but afraid you miles away from me and as im dieing with man flu atm cant look up any diagrams at work Sad
PostPosted: Mon Mar 21, 2016 7:18 pm    Post subject: Reply with quote
Thanks Dermot. Whilst I'm thinking the ignition is a bit iffy being so old soe changing this can be treated as preventative maintenance, like you I'm leaning toward something from the direct source of power.
I've no battery isolator and I checked the leads which are nice and tight. The earth strap is fixed well to the vehicle body. I perhaps need to play about more in that area.
I did manage to 'replicate' the incident on the drive after getting home but not sure if that was ignition key related or another coincidental bad connection given that teh clock stopped again etc Dont know
PostPosted: Mon Mar 21, 2016 7:29 pm    Post subject: Reply with quote
I think the ignition switch has shear off bolts ? if so might be a bitch to diy.
The clock seems to be the clue but could you check and make sure you have no interior lights as well when the fault happens.
There seems to be many places the battery +ve connects to so im struggleing to thinkl of anything other than that im afraid.
Have a good look at the positive side , see if you can follow the leads a bit to see if theres some sort of connection , its also possible to lift up the main fuse board to look for burnt wireing , couple of fixings to undo but do it with the battery disconnected Smile
Gazc2
Watkins Glen
PostPosted: Mon Mar 21, 2016 8:31 pm    Post subject: Reply with quote
Now that the siver surfer has all these problems happy to take it off your hands for the market rate of 25 bags of sand to alleviate your pain Very Happy
2007 997 Turbo & 924s Restored
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
Jcx
Estoril
PostPosted: Mon Mar 21, 2016 8:54 pm    Post subject: Reply with quote
It doesn't need to work to look good. Just polish it up and park it in your lounge and spend all evening just staring at its beauty.
Just don't drive it... Oh wait, it doesn't go Wink
Waz
Estoril
PostPosted: Mon Mar 21, 2016 9:07 pm    Post subject: Reply with quote
Just because the earth strap is tight to the body doesn't mean it's a good connection !
Undo it clean it de-rust it and reapply, do the same at both poles on the battery,
If you don't believe me ask Infrasilver, his was the Same, whilst on tour Thumb
Edit to check it next time it fails attach a jump lead between - and a good earth
May the Forsche be with you
2004 3.6 996 C4S cab in The fast black
Cayenne turbo S in matching black 600bhp
PostPosted: Wed Apr 06, 2016 6:53 pm    Post subject: Reply with quote
Before I clear some space in my lounge to mount the Silver Surfer on a onyx plinth as an ornament I've had the issue again PC
Drove it back from the service at my Indy and all was well. Parked on the drive and a few hours later car unlocked via alarm fob, ignition on (all lights) and then when I went to engage the starter motor I heard the solenoid click..............then nothing. All went dead and total power off.
Tried fiddling with the key no joy (ruled this out). Few minutes later all lights on, go to turn over, solenoid clicks then nothing - dead again PC Left a few mins repeated and then started no problem.
I've since then tried to replicate the problem but cant. Starts every time, starter cranks perfectly and 12.4v on standing battery.
I've been reading up in Streather's book and there is a 'suggestion' poor connectivity to the starter motor can cause 'all sorts of electrical issues' and wonder if the demand by the starter on the battery (via the earth strap(s)) is causing a circuit break somehow Dont know
I'm now leaning toward the battery/starter connectors so just ordered a new earth strap what
Sound about the right way to go Dont know
PostPosted: Wed Apr 06, 2016 7:13 pm    Post subject: Reply with quote
Well ... hmmm .. you have an engine earth strap which could well be faulty .. But .. you have a battery earth strap that would still give electric power to everything else , something is dropping the entire battery connection to everything .. after re reading posts , im still back at what on the wireing diagram shows some sort of + ve connection point that several wires come off from that feed everything , its got to be at that point i think.
The starter draws a huge amount of current so thats breaking the connection thats faulty , its just so randome is the problem .. need it to pack up , easy fix then lol
tell you what .. take a long drive to Sussex and ill drag out a voltmeter and have a look for you Smile
PostPosted: Wed Apr 06, 2016 10:19 pm    Post subject: Reply with quote
Any ideas where this 'connection point' will be as it appears the positive wires run underneath the spare wheel and then up behind the fuel tank and I wouold expect them to go to the motherboard of the fusebox Dont know
ras62
PostPosted: Thu Apr 07, 2016 8:29 am    Post subject: Reply with quote
Positive runs straight to the starter iirc which isn't easy access. It's a common point for bad connection so worth undoing and applying copperslip on re tightening. One important point. Disconnect the battery + terminal before doing the job. A short to earth is easy to do in that tight space and will make quite a bang.
PostPosted: Thu Apr 07, 2016 7:02 pm    Post subject: Reply with quote
Ive been looking at the wireing diagram i posted on my first post to figure out this problem , at K 50 it shows the battery and the feed wires .. off hand i dont know location but we have a 964 in atm so ill have a look tomorrow.
Im expecting though that it will be in the fuse board , the board can be pulled up to inspect underneath .. hell of a lot of wires though and do it with battery disconected if you want to look.
Goto page 1, 2, 3  Next
Page 1 of 3
