991 : 2011- 19
997 : 2004- 76
996 : 1997-2005 34
993 : 1993-1998 7
Cayenne : 2003- 4
deutschland-dobson
PostPosted: Fri Feb 19, 2016 1:40 pm    Post subject: Thermostat to oil filter pipe line Reply with quote
Gents,
I’m renewing a couple of oil lines (as you do) Rolling Eyes
Has anyone had experience of buying the thermostat to oil filter pipe line from Design 911?
Code: 96420725408
http://www.design911.co.uk/fu/prod2902/Oil-Pipe-Thermostat-to-Oil-Filter-Porsche-964-1989-94--96420725408/
I have a choice between OE Porsche and OEM Brand. I know the lads in the States have had problems with the quality of the OEM one in the past from other suppliers. The pipe kinks on fitting and restricts oil flow Surprised
The OEM is a fair saving over the Porsche one, but don’t want to make a mistake!
Chris
Porsche 911 (964) C4 - Project RED - Outlaw4
Guards Red & Linen, Custom Leather, BBS LM Split-rims, H&R Coilovers, Cleaned Bodywork, 90s audio instal...
SEE YA
PostPosted: Fri Feb 19, 2016 5:31 pm    Post subject: Reply with quote
Be careful, the thread can be removed from the thermostat when you undo the pipes. As I found out myself, not cheap either.
EVERY MILE IS A SMILE
SEE YA
deutschland-dobson
PostPosted: Sat Feb 20, 2016 7:00 pm    Post subject: Reply with quote
Thanks for the tip thumbsup
Pipe has been off twice before, recently, so should be ok. Pirtec made a replacement, just I'm not happy with the fit.
Chris
backitoff
PostPosted: Sat Mar 05, 2016 10:40 am    Post subject: Reply with quote
I replaced all of mine with genuine parts from my local OPC. Not the cheapest route, but I figured that the originals had lasted 25 years, and the replacements will fit as intended, it was the way to go. Only item not OPC is the oil cooler, which was a remanufactured item from Germany.
deutschland-dobson
PostPosted: Sat Mar 05, 2016 6:12 pm    Post subject: Reply with quote
Thanks bud Smile
I bought two OPC pipes and quality is perfect.
Chris
