Demort said:Check the fuses in the main fuse board , if ok then you need to remove the PCM and check the fuse on the rear of it .. its possible there was a voltage spike but unusual , if the leads were at any point reveresed then the pcm fuse will often blow.
If fuse ok then you need to check feeds/earths to the PCM , i cant rember the wire colours off hand but its the black plug , its the thick wires and you should have a permanent feed , an ignition on feed and an earth .. if you have them and the fuse is ok then its not looking good
Also unplugging the pcm and leaveing it unplugged for 10 mins or so may .. just may bring it back to life .. disconnecting the battery and leaveing for 10 mins would also have the same effect.
