I intend to fit a VDO gauge and to insert the sender into the sump sidewall (actually the wall of the crankcase).
There looks to be a suitable area at the gearbox end on the opposite half of the crankcase from the oil filter, this area is flat and has reasonable access.
I plan to remove the bottom plate and then drill and tap the sidewall for the sender but before I start it would be very helpful to know the wall thickness of this area to see if it's feasible.
Does anyone have an engine in bits and who would be kind enough to measure wall thickness of this area?
Thanks in anticipation!
