Hi all,
Just identified a significant oil leak. Basically the outer oil cooler pipe looks like it has been rubbing on the front jacking point and basically worn through... (see image below)..... Is this a common thing? I am thinking maybe it has had a ding at some point as I dont think the pipe should be this close to the jacking point....
I am thinking I will just replace the damaged pipe as it hasn't corroded but am open to suggestions if it is recommended to replace both and the question is should I replace anything else while having the job done such as the thermostat??!!
Any advice gratefully received...
Lig.
Lig.
