I see according to Autocar today that the new Boxster will have four cylinders (we knew that) but will be more expensive than the outgoing 6 cylinder car.
I'm somewhat surprised by that.
2016 Porsche 718 Boxster revealed
The most powerful version of Porsche's all-new, turbocharged four-cylinder petrol engine "¨will have a capacity of 2.5 litres and produce up to 345bhp in the facelifted Boxster S.
The model, which has been renamed 718 Boxster S following Porsche's decision to resurrect its hallowed 718 nomenclature, is set to get its first public airing at the Geneva motor show in March. The revised two-seater will be joined by the more keenly priced 718 Boxster, which runs a 2.0-litre variant of the horizontally opposed four-cylinder turbo engine making 296bhp.
The new models will be available from April, with an even more powerful 718 Boxster GTS due next year. At £41,739, the 718 Boxster is priced £1641 above the outgoing Boxster, while the 718 Boxster S costs £50,685, £2142 more than the Boxster S.
Distinguishing the 718 Boxster and 718 Boxster S from the outgoing models is a series of styling changes, including a new front bumper sporting larger cooling ducts, and larger air ducts in front of the rear wheel arches. The rear sports a distinctive new accent strip between the tail-lights to give additional visual width.
The 718 Boxster is the first Porsche to be powered by a four-cylinder engine since the 968 ceased production in 1995. Development of the new unit was overseen by Wolfgang Hatz, the head of Porsche's research and development operations suspended in the aftermath of parent company Volkswagen's dieselgate affair.
The new engine is also earmarked to replace the existing flat six in the 718 Cayman, which is also expected to make its debut in Geneva.
With 296bhp and 280lb ft, "¨the 2.0-litre unit makes 25bhp and 66lb ft more than the naturally aspirated 2.7-litre flat six it replaces in the outgoing entry-level Porsche roadster.
Significantly, peak torque appears 1500rpm earlier in the rev range than with the old six-cylinder unit, leading to what Porsche describes as 'added levels of low-end urge and greater mid-range flexibility".
The 718 Boxster S "¨receives a larger, 2.5-litre variant of the flat four turbo powerplant in place of the naturally aspirated 3.4-litre six-cylinder unit currently used. With 345bhp and 310lb ft between 1900 and 4500rpm, the new engine offers a 25bhp increase in output over the "¨unit it replaces, along with a 37lb ft lift in torque.
As before, the most affordable of Porsche's "¨sports car models offer the choice of a standard six-speed manual or optional seven-speed PDK dual-clutch automatic gearbox, the latter of which has been updated "¨with a new software package that's said to provide added fuel-saving potential.
Porsche says the 718 Boxster has a 0-62mph time of 4.7sec and a 171mph top speed when fitted with the optional PDK gearbox, bettering its predecessor by 0.9sec and 5mph respectively.The 718 Boxster S has claimed figures of 4.2sec "¨and 177mph, in the process beating the official 0-62mph time of the 380bhp 3.8-litre "¨six-cylinder Cayman GT4 "¨by 0.2sec.
As well as providing added power, the new four-cylinder engine also brings a significant improvement in fuel economy over the outgoing six-cylinder engine. The 718 Boxster returns a claimed 40.9mpg on the combined cycle and the 718 Boxster S promises 38.7mpg in combination with the PDK gearbox, representing improvements of 5.1mpg and 4.2mpg respectively.
Along with the new engine, the 718 Boxster features what Porsche describes as a 'sportier tuning of the chassis". Among the changes is a revised electro-mechanical steering system that is said to be 10% more direct than the set-up used on the outgoing Boxsters. Porsche's Active Suspension Management (PASM) continues to be offered as an option, offering a nominal 10mm reduction in ride height over the standard suspension.
