997 : 2004- 67
996 : 1997-2005 34
Macan : 2014- 6
rkelly
PostPosted: Mon Feb 01, 2016 9:17 am    Post subject: Reply with quote
Unfortunately this is not the update I wanted to be posting here. After a one month dispute; FVD have finally accepted that there is a problem with the parts they supplied me with.
Initially, they refused to accept there was a problem with the rods that I returned. As a consequence, they would not send me a replacement set of rods as they believed we were making a mistake. I was repeatedly told "we have sold hundreds of these rods and have never had a problem". As you can imagine this caused considerable frustration to my engine builder and myself.
This stalemate went on for several weeks until they finally tried to fit the rods to a 964 crankshaft. What took my engine builder 10 minutes to see, took FVD 2 weeks to recognise. I did not even receive and apology for the inconvenience caused. They did offer to sell me another set of rods at 10% discount. This wouldn't cover the cost of my time and my engine builders time to resolve this issue. Not to mention the fact my engine build has been delayed by over a month.
They have sent these back to Carrillo to be checked and I have received a refund. I fully accept that manufacturing errors can happen however, the customer service experience to reach this conclusion has been appalling.
It appears I will use the factory rods for my build now. I have spoken to George (my engine builder) about this and it appears I owe Ken an apology. The bushing/pin size is compatible with the 3.8 pistons. It is the rod width to fit the piston connection that needs modified. As Ken has said here, I simply need to machine the SE width down from 25 mm to 23 mm to fit the piston connection. I will order new fasteners this week and hopefully the build will resume next week.
Sigh...
Porsche 964 Carrera 2
Chief
PostPosted: Mon Feb 01, 2016 1:27 pm    Post subject: Reply with quote
Sorry to here about your problems sunshine...
Goes to show how lucky we all are on here to have the likes of Ken and Dyno Mike to show some clear headed thinking and wisdom. Thanks for being there guy's Thumb
Good luck with the rest of the build and let's hope it's plain sailing from here on in. Keep us posted thumbsup
996ttalot
Approved Trader
PostPosted: Mon Feb 01, 2016 5:04 pm    Post subject: Reply with quote
Have to say not surprised - every 3.8L 964 we have done including last month we always have machine work to make everything fit, even using Mahle.
I presume you have checked that the barrels fit the heads? We always machine those to fit a better sealing ring as a matter of course.
If I had a pound for every aftermarket shop that said we have fitted/sold hundreds I would be retired Grin - in most cases they don't have a clue I'm afraid.
Let's hope it moves forward quickly now.
I would suggest you make sure your builder measures the compression before you get too far in your re build. DO NOT assume that the compression they tell you is correct. I know a lot of engines that have blown up relying on what they have been sold when in fact compression is different. Also compression will change higher if you have to machine the heads/barrels and reduce is you do valve work.
Good Luck Thumb
nineexcellence.com
Tel: 01293 226911. Follow us on Facebook www.facebook.com/Nineexcellence
SALES, SERVICE, UPGRADES
rkelly
PostPosted: Mon Feb 01, 2016 7:50 pm    Post subject: Reply with quote
Hi Chief/Ken,
We have checked the new barrels already. My engine is an M64/1 so my heads do need to be modified. This is already the plan. The heads will get machined this week along with the rods.
Thanks again for the input.
Cheers,
Ryan
 Filesize:  392.75 KB
 Viewed:  3818 Time(s)
crz21
PostPosted: Mon Feb 01, 2016 9:22 pm    Post subject: Reply with quote
At least its progress Ryan, if not what you had planed.
1990 Guards Red 964 C4, deCat & G-Pipe. Bilstien with H&R turbo springs.
2004 Audi A4 Avant 1.8T.
2007 Z4 3.0si Coupe.
paul284pt
PostPosted: Tue Feb 02, 2016 9:44 am    Post subject: Reply with quote
I'd agree with that Ken. When Redtek did my 3.8 build (Mahle pistons) there was quite a lot of machining to do. I don't know how people manage to tackle these builds at home, they must have big ****s Grin
Good luck Ryan, I hope all goes well!
Cheers,
Paul
1980 - 84 924 Turbo with mods. (ex Tony Dron - 12th at Le Mans 1980 with works 924 Carrera Turbo).
1984 - 89 911 SC (1982)
1989 - 93 911 Carrera Sport (1989)
2010 - 964 Carrera 2 (1990) Redtek 3.8RSR
2012 - 14 Porsche Cayenne (2012)
2015 - 17 Porsche Cayenne Diesel S (2015)
2017 - 18 Macan Turbo Performance Package (2017)
2018 - 991.2 Carrera 4 GTS (2018)
rkelly
PostPosted: Fri Feb 12, 2016 5:24 pm    Post subject: Reply with quote
Hi Ken,
What supplier do you use for the barrel to head sealing ring/gasket? It sounds like you typically use a non standard item. Something like this?
http://www.fvd.de/de/en/Porsche-0/-11-20/-/-/item/item_details/VID_22949476-VCD_36862159-gid_39-sort_4-display_50-item_FVD104999993/Tuning_-_Engine_-_Sport_Piston___Cylinder_FVD104999993_Gasket_`Le_Mans`_113mm_only_for_MAHLE_Cylinders_3_05mm.html
I can't seem to find anything suitable on the patrick motorsport website.
Cheers,
Ryan
996ttalot
Approved Trader
PostPosted: Sat Feb 13, 2016 12:18 am    Post subject: Reply with quote
rkelly wrote:
Hi Ken,
Cheers,
Ryan
Ryan
Send me a PM.
Ken
nineexcellence.com
Goto page Previous  1, 2
Page 2 of 2
