997 : 2004- 68
Boxster : 1997- 31
PostPosted: Wed Dec 23, 2015 8:13 pm    Post subject: Checking the IMS bearing and removing the outer seal Reply with quote
As some will know, my clutch went last week, so it's with my mechanic at the moment having a new one fitted.
Upside to this is we have access to the legendary IMS bearing. So with all the knowledge and learning I've gained from this wonderful website, I decided we'd have a poke around and check things out. Just got back from the garage now so perfect timing to do a quick write-up before I go out to sink a few ales (to celebrate my findings Smile ).
Before we did anything with the IMS bearing here's the sate of play:
Gearbox and clutch removed ready access.
RMS is fine and in good shape.
IMS cover-plate seal had not been fitted correctly by OPC (back in 2005) thus scuffing one side of the seal allowing oil to get out and cause a (very minor) weep
Gearbox to engine bolts had been fitted incorrectly by OPC and a long one in a short hole had snapped part of the engine casting off and stripped the bolt.
My mechanic called me an hour ago to tell me we ready ready for the unveiling of the IMS bearing (engine locked in TDC, both tensioners at that end of the shaft slackened off, oil drained).
Once we removed the seal, no grease apparent, just black oil came seeping out. Bearing was original dual row bearing (of which he says they're the same as they use in some tractor applications and can easily acquire them) and once the seal was removed, inspected to find it it in immaculate condition. Absolutely zero play in it and unable to turn the ball bearing cage without the internal one spinning twice as fast. thumbsup
With the outer seal now pinged off (so lubricated off nice clean engine oil) and the bearing in immaculate condition, it's all getting popped back together with the peace of mind if hopefully won't go pop in the future.
I must say - it's amazing how small this thing is. No wonder they couldn't handle it.
As usual a few snaps to oggle at Grin
The long bolt shredded at the end.
The broken casting,
The bearing as left the factory.
The unveiling.
Dirty black stuff.
Car should be back together later tonight and ready to pick up in the morning with new clutch fitted and properly lubricated IMS bearing with no snake oil fomula required!!!
Merry Christmas!! thumbsup Smile
Chris_in_the_UK
Estoril
PostPosted: Wed Dec 23, 2015 8:15 pm    Post subject: Reply with quote
thumbsup
2006 Cayman S PCCB's
Harv
PostPosted: Wed Dec 23, 2015 10:45 pm    Post subject: Reply with quote
Nice work, I bet your glad the bearing has zero play and dosent need replacement in situ!
What bunch of monkeys put the wrong bolt in that position of the bell housing WTF Surprised presumably there's nothing that can be done to remedy?
I had the exact same oily goo residue around my ims ( sounds rude ha ha) so perhaps the seal on the cover plate deteriorates with time and slowly allows seepage. Don't forget to use thread seal on the 3 bolts for the ims cover plate if you are not replacing them
Thumb Thumb
Chris_in_the_UK
Estoril
PostPosted: Wed Dec 23, 2015 10:55 pm    Post subject: Reply with quote
Looking at the bolt hole, I guess it could be TIG welded up and re-tapped?
paul987
PostPosted: Wed Dec 23, 2015 11:14 pm    Post subject: Reply with quote
Great pics Alex.
good news on the IMS Thumb
I still think a little snake oil should be considered Dont know Laughing
A truly wise man never plays leapfrog with a Unicorn.
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
kas750
Shanghai
2006 Porsche 911
PostPosted: Wed Dec 23, 2015 11:44 pm    Post subject: Reply with quote
Happy days! thumbsup
New997buyer
Banned
PostPosted: Thu Dec 24, 2015 5:38 am    Post subject: Reply with quote
thumbsup
Good write up. And like most owners it's things like sheared bolts etc, plus the er clutch, that are your actual running costs. Not the IMSB Grin
My understanding is the vast majority, by a significant factor, handled it very well. Dont know
Anyhoo glad yours will be back in time for santa thumbsup
arry
PostPosted: Thu Dec 24, 2015 7:29 am    Post subject: Reply with quote
It always makes me wonder why so much credence is given to cars with OPC only history that they're going to be meticulously maintained by only the finest mechanics when you see threads like this (excuse the pun!) - that's really shoddy from them
Good news on the bearing. If I remember right your car is on about 80K?
2001 Lapis Blue 996 C2 Manual
2012 Orange KTM 990 SMT
2016 Marsh Grey Royal Enfield Bullet 500
Chris_in_the_UK
Estoril
PostPosted: Thu Dec 24, 2015 8:07 am    Post subject: Reply with quote
I tend to agree - the trouble and 'issues' often go unnoticed as a lot of people can't or won't do any work themselves or step outside the OPC network. There was a thread on PH a while ago where somebody had discovered a set of mole grips clamped onto a damper rod following some suspension 'work' being done at an OPC.
Sure there are some decent one's though.
PostPosted: Thu Dec 24, 2015 8:56 am    Post subject: Reply with quote
82k at purchase in Feb '13, now at 102k.
You only have to read the previous invoices off OPC to realise the ones that worked on mine were useless (gearbox off 3 times in 12 months for 2 clutches and an incorrectly fitted ims seal, fitted after it wasn't diagnosed correctly after the first 2 removals).
I've started to realise there's 4 types of people who work on these cars:
1.OPC monkeys not trained and capable to do what they're employed to do.
2. Snake oil "specialist" Indies who charge the same as OPC (if not more) due to their 'knowledge & experience' of working on a highly engineered mythical auto-mobile.
3. Your all round intelligent good mechanic (some Indies fall in this bracket).
4. The owners.
Trick is two know who you can trust and who you can't.
New997buyer
Banned
PostPosted: Thu Dec 24, 2015 9:09 am    Post subject: Reply with quote
4. The owners.
I agree with the last line (sic) and would suggest an amended list.
1 - Those who know what they're doing and you can trust.
2 - Those you can't.
The above types may be anywhere, OPC or otherwise. Thumb
As for the 'snake oil "specialist" Indies' comment that's a bit sweeping, surely? Hartech, Porsche Torque, 9E, Dove House, Parr, Fearnsport and many others have a fabulous reputation for a very good reason. In fact one of the reasons I can afford to run a 996 turbo as a well used daily is the above and beyond care and attention of my Indy. Same with my 996.1 which was as well cared for by Chris Turner as the 356's, 911E's and so on the he specialised in.
So I'd go easy on the generalisation that Indies are less than trustworthy Rolling Eyes
PostPosted: Thu Dec 24, 2015 9:14 am    Post subject: Reply with quote
4. The owners.
Smile
Niall996
PostPosted: Thu Dec 24, 2015 9:57 am    Post subject: Reply with quote
Very good. I thought the bit about dual row bearings being still used in tractors and therefore readily available was interesting. The belief as I understood it was that this bearing could no longer be sourced.
PostPosted: Thu Dec 24, 2015 10:14 am    Post subject: Reply with quote
Same here.
Chris_in_the_UK
Estoril
PostPosted: Thu Dec 24, 2015 10:29 am    Post subject: Reply with quote
Out of curiosity does anybody know the width of the dual row bearing?
PostPosted: Thu Dec 24, 2015 10:37 am    Post subject: Reply with quote
I'm guessing it's something like this: 47mm od x 20mm id x 18mm wide????
http://www.skf.com/group/products/bearings-units-housings/ball-bearings/deep-groove-ball-bearings/double-row-deep-groove-ball-bearings/double-row/index.html?designation=4204%20ATN9&unit=metricUnit
Chris_in_the_UK
Estoril
PostPosted: Thu Dec 24, 2015 10:40 am    Post subject: Reply with quote
Dont know
I seem to remember Baz saying that the issue was the bearing thickness being an oddball size?
Just curious what it was?...
PostPosted: Thu Dec 24, 2015 10:46 am    Post subject: Reply with quote
It was a Dual row 6204 bearing.
Chris_in_the_UK
Estoril
PostPosted: Thu Dec 24, 2015 11:17 am    Post subject: Reply with quote
There are a few thicknesses available though ranging from 17mm up to almost 21mm.
kas750
Shanghai
2006 Porsche 911
PostPosted: Thu Dec 24, 2015 11:27 am    Post subject: Reply with quote
Interesting comments about some of the indies..I have blood running down my chin from biting my tonque. thumbsup
Good progress on this BTW Alex. Thumb
Goto page 1, 2, 3  Next
Page 1 of 3
