Boxster : 1997- 14
Cayenne : 2003- 3
Gazc2
PostPosted: Mon Oct 03, 2016 3:13 pm    Post subject: Reply with quote
Ive never tried that before holding the car up with the handle on the trolley jack Very Happy
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
 Filesize:  233.45 KB
 Viewed:  5438 Time(s)
dommorton
1998 Porsche 993 Carrera 4S
PostPosted: Mon Oct 03, 2016 5:24 pm    Post subject: Reply with quote
Oh Car-o-liner
I'll get my coat Get Me Coat
Good cars can get you from point A to point B. And great cars? Well, they'll just get you into trouble.
Cameltoe & Heel
PostPosted: Wed Apr 19, 2017 1:56 pm    Post subject: Reply with quote
Folks,
some more progress made recently so I thought I'd post some pics:
Car loaded and ready for trip to the garage:
Work is being done at CrashUK in Bolton, you can judge the workmanship for yourselves.
Being winched onto the jig:
Sat on jig but still on trolley:
Car now secured to jig with custom welded brackets, N/S rear leg was 4mm (due to wheel impact) out of factory dimensions where the side panel bolts to the chassis leg, so pulled straight.
Trick here was that it was only out in one spot so had to hold the remainder of the leg solid hence chain and bracket being held from O/S, and RAM from N/S.
Rear view:
Ram setup on O/S now ready to pull small indent from chassis leg due to wheel impact, chassis leg this side was spot on and well within factory tolerance:
Here you can see how Colin has welded two plated onto the chassis to pull out the O/S indent damage:
A clearer shot:
After pulling straight, removing plates and cleaning up:
Now fill the area:
It's always best to pull the damage in the panel back to where it was to ensure the best fit when installing new panels:
Same on N/S, impact pulled back on panel, not to save panel just to ensure everything goes back to where it should be:
All engine aperture measurements taken and compared to factory, rear quarters now removed on both sides as well as the top scuttle panel.
And with those panels goes the inherent Targa rust beneath roof problems Smile. New panels will receive plenty of layers of protection along the top edges of the panels to ensure rust will not return.
O/S without rear quarter:
N/S without rear quarter, notice how the sill has been cut ready for new panel, this juncture will butt to new panel and be braise welded to ensure reduced distortion compared to Mig, braised welds are also much better for rust prevention.
Rear quarters clamped on for mockup purposes at this stage. The quarters will be spot welded as per the originals however Colin is going to use additional special panel bonding which conducts allowing you to spot weld through. this should help give the panels more rigidity and hopefully the chassis. Spot weld locations noted to ensure perfect match to original panels.
Rear quarters are now primed on the inside and will be seam sealed:
Checking door gaps on mockup:
Much more to come within next few weeks, paint is booked in for 2nd May.
Trev
Millomboy
1997 Porsche 993 Targa
PostPosted: Wed Apr 19, 2017 3:52 pm    Post subject: Reply with quote
Epic. Bow
Ocean blue targa.
The only true freedom, is freedom from the heart's desires. And the only true happiness, this way lies.
NottsRS
PostPosted: Wed Apr 19, 2017 3:57 pm    Post subject: Reply with quote
Good work Trev. Get stuck in there boy thumbsup
964 RS | GP White | Lightweight
993 RS | Riviera Blue | Lightweight
997.1 RS | RS Grün
993 4S | Viola Metallic | Factory Non Sunroof | [Jan'09-Mar'16]
MilSub
PostPosted: Wed Apr 19, 2017 4:21 pm    Post subject: Reply with quote
Incredible work Trev - have just read the whole thread worship I had no idea that machinery like the car-o-liner existed - amazing pictures, amazing story!
1996 Carrera 4
Cameltoe & Heel
PostPosted: Wed Apr 19, 2017 5:49 pm    Post subject: Reply with quote
Thanks guys, glad you enjoy the story so far, long way to go yet but it should start coming together soon.
Colin did my Mitsubishi Shogun 4 Work which I bought with a smashed in front end, did a great job on that and I've been using that for the last three years and serves as my work horse for parts runs, tip runs and often as my daily commuter if the mrs has the Range.
His usual work is on top end sports cars, repairing Lambo's, Bentley's, Fezza's etc which have real damage so this is nothing to him. He's a real enthusiast of his trade, and it comes across when you talk to him. The tools he has are just amazing.
Colin's really enjoying working on the 993, says the build quality is amazing and very rust free for a 20yr old beast.
I'm going to pick up two new check straps from Porsche Bolton tomorrow lunch so will pop in and see the work in the flesh
Just wait to you see his welds Smile
Trev
h2no
1995 Porsche 993 Carrera 2
PostPosted: Wed Apr 19, 2017 8:32 pm    Post subject: Reply with quote
Loving your thread, will be interested in the door straps tomorrow, as I need mine done too.
Jet Jock
PostPosted: Wed Apr 19, 2017 9:18 pm    Post subject: Reply with quote
Thread just gets better. Thanks.
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, FD Motorsport SSK and Golden Rod, MPL Clutch Slave Cylinder, HID conversion...
Instagram: bazzer_a
AP90
PostPosted: Thu Apr 20, 2017 8:05 pm    Post subject: Reply with quote
Thank you for taking the time to shoot and post, very interesting
Cameltoe & Heel
PostPosted: Fri Apr 21, 2017 12:17 pm    Post subject: Reply with quote
Ok chaps, hope you don't mind picture overload:
This was inside O/S rear quarter, great protection applied at the factory which we've looked to replicate where we can:
Inside the new quarter which has been primed and seam sealed in the appropriate areas, including right down to the sill, all done prior to fitting to ensure access:
Method used here was to use a brush initially and then a spreader with a course sponge attached to get the correct texture.
And again:
Tops of the inner wings were dirty but also showing some small rust spots which needed to be remediated correctly:
O/S not as bad:
Down to bare metal:
Now upper inner wings treated with this 2k high build primer brushed on nice and thick.
Rear quarters are being spot welded on today, Colin asked which pattern I would like, his regular or follow Porsche?, i said to follow the Porsche pattern although it doesn't really matter as the roof sits here and hides all welds. It's inside the rear engine compartment where the visible welds are Smile
Will post pics of the welds v.soon.
Trev
BHZ661
PostPosted: Fri Apr 21, 2017 2:16 pm    Post subject: Reply with quote
Fantastic read and looking forward to updates thumbsup
Cameltoe & Heel
PostPosted: Mon Apr 24, 2017 7:42 pm    Post subject: Reply with quote
Right chaps a few more updates......
Prepped with black panel bond ready for new quarter, have to be quick as the bond goes off.
Rear quarter fitted and sill now ready for welding, decided to go with mig welding in the end for strength.
Trying a few test spots:
Sill now welded and prepared:
Quarter spot welded and panel bonded along top edge following the original pattern of spots:
Along the door seam here was tricky due to a small lip on the rear:
Along the engine bay aperture is very important as it can be seen when opening the engine lid, Porsche pattern and precise copy of original weld made here:
Just some of the equipment used, never underestimate what investment it takes to perform works on a car if you're going to do it right:
Rear quarter now in place, you can see the seam of black panel bond from within the wheel arch, this will be cleaned up a little and another line of dealer applied to keep out any nasties:
Engine aperture now with both rear quarters fitted:
Cameltoe & Heel
PostPosted: Fri Apr 28, 2017 3:50 pm    Post subject: Reply with quote
OK so whilst the car was at the bodyshop it was time to fix the check strap arresters. Mine was making the dreaded clicking sound on both sides which just wouldn't do.
Anybody who's looked into this will know there's a few ways to do the job,
1) Quick blob of weld on the outside to hopefully hold it
2) Cut window into the A post and re-weld the joints properly
3) Install new Porsche A post which have modified welds and additional strength so I believe?.
I've opted for option 2 as it seems somewhat less intrusive than replacing the full pillar.
We can see the state of the welds here on the A post, not good:
After a cleanup:
Whole section required cutting out:
New steel sections making for both sides:
Section offered up with two holes for the weld:
And primed:
Ready for welding:
Welded and made good, now just needs some primer before going to the paint shop:
Lots of work but the job needs doing right.
Trev
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Sat Apr 29, 2017 2:33 am    Post subject: Reply with quote
Fab thread Trev, really enjoying the detail and the many pics..
Rgds
Barney.
Ex. '99 996 C2 manual coupe.
Cameltoe & Heel
PostPosted: Thu Oct 18, 2018 9:23 am    Post subject: Reply with quote
Folks, not updated for a while so thought I'd bring you up to speed.
I've finally got the car back from paint, as some of you know already I decided to go with a colour change, well partial, from Ocean Blue to Mexico Blue.
Glad to have the car back and progress is now in my hands Smile
Being loaded at paintshop
Unloading my end:
Finally in place:
Had the hardbacks sprayed to match body
Rebuilding begins
Engine bay starting to come together
New engine pad and engine bay seal, fuel filter...
Powder coated bumper supports and rear quarter supports
I really like the 993 door handles Smile
I shall post updates as they come...
Trev
NottsRS
PostPosted: Thu Oct 18, 2018 10:07 am    Post subject: Reply with quote
Great job mate! Salut
997.1 RS | RS Grün
decgraham
PostPosted: Thu Oct 18, 2018 10:42 am    Post subject: Reply with quote
Looking the dogs dodahs Trev Thumb
ATB Smile
stichill99
PostPosted: Thu Oct 18, 2018 11:38 am    Post subject: targa Reply with quote
Great opportunity to go for a colour change. Looks the Bee's Knee's Very Happy
PostPosted: Thu Oct 18, 2018 2:51 pm    Post subject: Re: targa Reply with quote
What a colour change! Ill be honest I don't get dark blue, but mexico blue worship worship wow.
991 C2S PDK with X51 430 powerkit in racing yellow, PCCB, PDCC, PSE, Carrera S alloys, Sports design kit and ducktail.
“Herman yellow, the last of the naturally aspirated”
EX 997.2 Carrera 4S PDK
EX 997.2 Carrera S PDK
EX 997 C2 gen 2 PDK
EX 993 Targa
EX 993 Carrera 4 manual
EX 996 3.4 Cabriolet
EX 986 boxster
Goto page Previous  1, 2, 3, 4, 5, 6  Next
Page 3 of 6
