996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
PostPosted: Thu Dec 21, 2017 9:45 am    Post subject: Reply with quote
ELA wrote:
All being well, I am now on track to have this project complete by spring, TUV approved and ready for review Very Happy
Looking forward to seeing it at Dinslaken. thumbsup
Marky911
PostPosted: Thu Dec 21, 2017 10:01 am    Post subject: Reply with quote
I was just saying to my mate Craig last night that there isn't much car stuff happening at the minute. My cars away, there are no decent bits popping up on eBay and not many good threads popping up....
So it's great to see an update on one of the best 996s out there. Glad you're getting there after the set backs. The parts are looking really good. Cool
Have a great Xmas Rich and hopefully swap the R&D for some R&R. Thumb
911munKy
PostPosted: Thu Dec 21, 2017 12:28 pm    Post subject: Reply with quote
Those suspension components look much beefier (and more gorgeous!) than the initial ones, were the first redesigns just to test the required geometry for the test drives?
This project is awesome, just awesome, thanks again for sharing its progress.
2000 C2 996
askgeez
PostPosted: Thu Dec 21, 2017 12:56 pm    Post subject: Reply with quote
Well done Rich.
worship
997.2 GTS coupe PDK
997.1 C4s coupe Manual (sold)
New997buyer
Yas Marina
PostPosted: Thu Dec 21, 2017 1:21 pm    Post subject: Reply with quote
Outstanding Mr B worship
“Forum signatures with quotes from famous people is a form of pretentiousness beyond compare, Sir!” Abraham Lincoln in conversation with Groucho Marx.
997.1 turbo man
Ex 997.1 turbo tip S, 996.2 turbo tip S, 996.1 C2 man
EGTE
PostPosted: Thu Dec 21, 2017 3:18 pm    Post subject: Reply with quote
Well done for hanging in there, Richard!
Sure it will be fantastic.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Thu Dec 21, 2017 3:34 pm    Post subject: Reply with quote
Glad the gearbox is sorted.
ELA
PostPosted: Thu Dec 21, 2017 8:15 pm    Post subject: Reply with quote
Thank you guys, many of you have been there from the start showing your support and offering many great ideas Thumb
Suspension designs have been changed progressively as my car is a development mule. If truth be told I thought my first attempt was perfect and would work just fine however a combination of excess weight or premature fatigue... have meant I've been back to the drawing board more often than I had ever envisaged. I guess that is just part and parcel of taking on something like this.
The main issue is I am trying many new ideas and this induces factors which create problems which you don't consider at conception. Adding 26mm into the length of an LCA for instance, throws up all sorts of issues. This latest design though will be perfect. They have literally just been finished this evening so I will add a few pics of the manufacturing process below.
My apologies is this comes across a bit OTT and I am happy to tone it down a bit if this sort of detail isn't to everyone's taste. I am perhaps just a little sad and a bit too excited with finally having a solution which alleviates all the previous design flaws.
Although these arms are a seriously well designed and overly robust construction for the intended lightweight 911 application, I have gone this route for various reasons:
-All three of the bushes can be replaced if the need ever arises.
-They will offer OEM levels of NVH.
-Extra weight and complexity of design is a compromise in order to achieve greater than OEM durability.
They are a combination of 5 different companies involved to get to this final prototype design. TUV approval to follow Thumb
CLR996 1086kg bespoke design
Dammit
PostPosted: Thu Dec 21, 2017 8:23 pm    Post subject: Reply with quote
Personally I love the details - more the merrier.
NickHappy
PostPosted: Thu Dec 21, 2017 8:48 pm    Post subject: Reply with quote
Amazing work - fascinating to see Thumb
997 turbo Manual.
996 turbo Manual. ex.
EGTE
PostPosted: Thu Dec 21, 2017 9:39 pm    Post subject: Reply with quote
Love those pictures. Thumb Thumb Thumb
Johnd52
2011 Porsche Cayman 987
PostPosted: Thu Dec 21, 2017 10:00 pm    Post subject: Reply with quote
I have absolutely no knowledge or experience of any value to add, but I have been following this from the start and will happily see it through to conclusion. Thanks for posting.
2015 Cayman GTS. No more PDK but still red.
alex yates
PostPosted: Thu Dec 21, 2017 10:54 pm    Post subject: Reply with quote
worship thumbsup
ELA
PostPosted: Fri Dec 22, 2017 4:32 am    Post subject: Reply with quote
alex yates wrote:
worship thumbsup
Yep the cameraman certainly has talent Wink
JS1500
PostPosted: Sat Dec 23, 2017 9:57 pm    Post subject: Reply with quote
I'm really looking forward to seeing the video reviews of this when it's all set up as you want it.
It'll be a fantastic drive, I'm absolutely positive. Cool
2000 996 C4 - Guards Red
Y2K
PostPosted: Sun Dec 24, 2017 12:14 pm    Post subject: Reply with quote
Great Christmas update Cool
2005 996 GT3 mk2
1999 Integra DC2
JohnnyDangerous
Estoril
PostPosted: Sun Dec 24, 2017 1:21 pm    Post subject: Reply with quote
Nice work Richie
I came into this world screaming and covered in somebody elses blood! I have no problem leaving the same way!!!
ELA
PostPosted: Thu Dec 28, 2017 5:36 pm    Post subject: Reply with quote
I'll be a little busy over the coming days Very Happy
Redesigned LCA's:
Also the castor arms:
Adjustable tie rods:
Easier to fill gearbox before fitting:
Added some trick friction modifier:
Now the job I've been putting off for a while; fitting the GB from the ground. These are unbelievably heavy. So far I've come up with an Egyptian like solution just for sliding it roughly into position but I've not thought about how I'll lift it just yet...
One again thanks for the encouragement guys.
It's great to finally be getting back to it again. Over the coming weeks I'll be looking at modifying the tie rods for weight reduction and making some jigs for the new suspension arms. Ideally if someone has an old hub assembly rotting away I'd be grateful if you could let me know. I would just like to chop one up to make a jig Thumb
DynoMike
2003 Porsche 996 Turbo
PostPosted: Thu Dec 28, 2017 9:16 pm    Post subject: Reply with quote
Looking very nice CLR Thumb
Try looking for some motorcycle jack pads to lift the gearbox up into place. There are some scissor lifts available for not much money, though where from eludes me at the moment, which will lift from about 75mm up to easily 350-400. They are just flat pads with an ordinary long screw operation, so easily operated with a ratchet. I will endeavour to find a link to one for you.
In fact, a quick scout around found a better one from wiltec_gmbh on eBay for £78.00. Perfect for you, as it is obviously a German company!
We managed to use one to help install a steel 570 litre air receiver a few weeks back, it lifted that baby with relative ease, so should cope with a gearbox ok.
Your project looks fantastic by the way. thumbsup
2003 996 Turbo
Previous toy 1974 Mini 1000
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Thu Dec 28, 2017 10:27 pm    Post subject: Reply with quote
Apologies for the rubbish picture but this is what I made to fit into a trolley jack. Flat plate steel with angle iron sides and tube that I welded on to allow it to slot into the jack. I then use wooden blocks and a strap to hold the gearbox onto the jack, it makes it easy to pull the gearbox away from the engine and then can lower easily in a tight space.
The hardest part is getting the gearbox back onto the jack for installation, as it won't slide under the cra on the jack but a couple of jacks to get it high enough to slide this jack under works fine. Without it, it's like wrestling with a crocodile under a car.
Goto page Previous  1, 2, 3 ... 35, 36, 37 ... 41, 42, 43  Next
Page 36 of 43
