poppopbangbang
Nurburgring
- Joined
- 25 May 2015
- Messages
- 480
So after three weeks away making V10 noise I've finally had a second to collate all the bits together for the way over the top front brakes that are going on my C4.
To recap these are Cayenne 6 Pots converted from lug mount to radial mount with specific brackets to allow them to mount to the C4 front upright. Discs are boggo Cayenne Turbo 350mm items with a smattering of drillings.
Caliper - these have been recoated silver to match with the original C4 silver caliper thing.
Lower view showing the bracket:
And the bracket:
You can see the bracket is machined to make a mechanical fit with the front upright for strength and rigidity. Also the caliper is machined to make a flat mounting face with the bracket again for rigidity. No silly spacers or opportunities for flex here!
Disc with a pound coin for scale.
These are generic grey iron Cayenne discs. I might drill them to take the 996 style retaining screws but as the current standard discs and the set before them have been running with no retaining screws it's not really neccesary.
Pads are default road car spec Pagids but obviously in a size suitable for stopping 2.2 tonnes of Cayenne from 160mph so on a 1260KG 996 they will be more than enough with the added benefit of good cold performance and very little brake dust.
I will try to get them on the car this coming weekend if opportunity presents itself. Then it's just a case of slinging the current 4 pots on the rear with 330mm discs at which point I WILL need to fit a 27mm master cylinder
Considerably better brakes than a GT3 for similar money to a pikey K-Sport brake kit
And the bracket:
