Recently I replaced both rear track control arms on my 996.
In both case the bolt was stuck fast (galvanic corrosion) inside the aluminium bushing.
Turning the bolt just trashes the bushing and the lot just spins inside the arm.
Impossible to get much heat on as its inside the arm, inside the bushing.
No room to get a grinder in.
The only solution I came up with was hours of hacksawing, OK for one bolt:
Now, I've got to do the rear coffin arms, and all 4 top dogbone links on the rears. Thats 10 bolts likely to be stuck fast similarly..... I'm not hacksawing through all those by hand.....
What methods do people use to get these bolts out? Any creative ideas? Or do I take it to garage and let them use an air die grinder (praying they don't cut through my subframes too....)
Anyone had success with a reciprocating saw?
