zedmeister
Active member
- Joined
- 23 Jan 2012
- Messages
- 26
I am trying to work out what problems I have with my alarm. There are 2 issues, the car does not respond to the remote, locking with key is fine. And there is a single beep when locking indicating that an alarm loop is open. Durametric gives the following:
9X6 Alarm Selected
About to get fault codes
moduleType = AlarmI32
dtcCount = 5
Fault Number: 10
Description: Alarm system/central locking system without function
Repair Infomation: Voltage failure at terminal 30 with alarm system active
Repair Infomation: Status: Not present
Repair Infomation: Number of times DTC present: 4
dtcCount = 5
Fault Number: 33
Description: No passenger compartment monitoring
Repair Infomation: Interior monitoring sensor faulty
dtcCount = 5
Fault Number: 60
Description: Central locking limit position locked not reached
Repair Infomation: Switch for central locking is faulty
Repair Infomation: Number of times DTC present: 7
dtcCount = 5
Fault Number: 46
Description: No central locking possible
Repair Infomation: Central locking synchronization
Repair Infomation: Number of times DTC present: 2
dtcCount = 5
Fault Number: 59
Description: Central locking limit position safe not reached
Repair Infomation: Open circuit or short to ground
Repair Infomation: Number of times DTC present: 3
My understanding is that if the Status says "Not present" then that fault no longer exists or am I wrong? I am unable to clear alarm fault codes with this version!
9X6 Alarm Selected
dtcCount = 5
Fault Number: 10
dtcCount = 5
Fault Number: 33
dtcCount = 5
Fault Number: 60
dtcCount = 5
Fault Number: 46
dtcCount = 5
Fault Number: 59
